Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
64 Starfire Rear Axle ID
Old Mar 7, 2010 | 12:46 AM
64starfire's Avatar
What is the name of this axle. I put in an overdrive trans and seriously considering putting in a lower gear in the back. Is it the B&P 8.2? BTW, I'm not at home (iraq), but paying (gag) someone to do the work for me or I'd go measure it myself.
thanks
Old Mar 7, 2010 | 05:26 AM
rocketraider's Avatar
Oldsdruid
Unless it was ordered differently, a Starfire will have 3.42 gearing. That's just about perfect for a street-driven 200-4R or 700R4. How low you thinking to go?
Application is 57-64 Olds and Pontiac. The big player gear companies have gears for them.
Old Mar 7, 2010 | 05:37 AM
64starfire's Avatar
Ok found out it's a GM 9.3" "C" axle. Here's the link to Richmond. http://www.richmondgear.com/07Apdfs/page29.pdf
Yeah, think I should get the speedo cal'd first before I do anything. I'll be home in April.
Old Mar 7, 2010 | 07:58 AM
wmachine's Avatar
Trying to remember member
I have it that with the M37 HD automatic, 3.64 and 3.90s could be had. Did any really come that way? 3.90s would really make a street monster out of the '64 Starfire (and JS1).
Old Oct 5, 2010 | 02:14 PM
Jakespeed63's Avatar
Starfire final drive ratios
I believe the 3:64 ratio (which is what I have in my 64 cpe) came standard with an A/C optioned car. They thinking or rational, was that motor would not have to work as hard with extra load of A/C.
I want to know more about the OD conversion. I have a good 200r4 and 700r4 in the garage. But adapter kits are almost a grand AND you supposedly have to cut the tunnel to make it work?? Gonna send a PM for more info.
JT
Old Oct 14, 2010 | 11:30 AM
mrolds88's Avatar
FYI your starfire should not need the speedo recal'd regardless what gears are in it as the speedo reads off of the front wheel.
Old Feb 2, 2011 | 05:10 AM
64starfire's Avatar
Follow up
As for getting the speedo recal'd, I had front disk brakes put in. Which worked out great for putting in the 700r4.
I'd still like to find a 3.64 or 3.90. I know there's a 4.10 with Richmond but it's a little high, would take away a large chunk of the gains from the overdrive.
HitTheHole
Drivetrain/Differentials
Feb 4, 2021 10:46 AM
cutlasssupreme71
Feb 22, 2011 11:40 AM
dan1s
Sep 23, 2008 01:53 PM
dan1s
Mar 16, 2008 11:13 AM
<powers455>
Sep 13, 2007 09:11 PM
