Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
62 Starfire Wheel Color?
Old Nov 7, 2009 | 09:45 AM
tpawlik's Avatar
Was the entire wheel painted the same color as the car or just the outside face and the edge next to the tire?
Thanks.
Old Nov 19, 2009 | 01:53 PM
Oldskeeper's Avatar
Tom,Are you referring to the hub cap or the steel rim because as far as I know the rim is black with steel inserts in the five gaps.The hub cap is painted to match the car but can also be painted to match other colors depending on the option list.
Steve
Old Nov 24, 2009 | 04:33 AM
tpawlik's Avatar
Thanks, yes I am inquiring about the rim. There is only about a 1/4" of rim that shows with the wheel cover on. I was wondering about the backside of the rim.
Old Nov 24, 2009 | 11:14 AM
Oldskeeper's Avatar
Hi Tom,as far as I can tell the whole rim was painted black,front,back and where the tire goes.The whole rim was painted a gloss black and then the tire was installed and the weights for balancing were installed.Whether you had the hub caps with the clips or the push on type the rim was the same.
Steve
RAMBOW
Dec 7, 2017 07:22 PM
orence1
Feb 1, 2015 03:14 PM
Oldssupreme
Feb 3, 2013 06:26 AM
Oldssupreme
Feb 3, 2013 06:24 AM
jvock6
Apr 30, 2012 10:31 PM
