Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
62 Starfire HVAC Vacuum Connections???
Old Dec 29, 2009 | 02:03 PM
tpawlik's Avatar
My car has the deluxe heater, no A/C. The 61 shop manual Fig. 16-29 shows the vacuum source as the fuel pump. I installed new vacuum hoses following Fig. 16-29. My car also has the vacuum tank shown on Fig. 16-38 Standard Heater. This shows a tee in the distributor advance line with the vacuum source being the carburetor. The tee connectes to the t-stat on the heater box inside the car.
I was about to reinstall the vacuum tank on the fire wall, but could not figure out what connected to it. Looking back at the pics I took before disassembly, there was a vacuum hose coming thru the firewall connected to the vacuum tank. I have not started the car yet to see if the system will work as it connected. Which way is right, can I eliminate the vacuum tank on the firewall?
Thanks.
Old Dec 29, 2009 | 02:32 PM
citcapp's Avatar
The vacuum tank on the firewall is keeps the vacuum working when you accelerate think of it as a storage tank you need to keep it
Old Dec 30, 2009 | 07:11 AM
tpawlik's Avatar
So, I need to route the vacuum source to the tank and then connect the outgoing line on the tank to the HVAC controls?
Old Dec 30, 2009 | 08:14 AM
chequenman's Avatar
Hose ?
I think if we're talking about the same vacuum tank, it might be the one that feeds the power trunk release....
Old Dec 31, 2009 | 06:34 AM
tpawlik's Avatar
That makes sense. I have not reconnected the trunk release. There is only one vacuum source at the rear of the carburetor. The power brake booster gets it's vacuum here. I can put a tee in the line and run that over to the tank. The tank looks like a fat soup can. It is mounted on the firewall, to the left of the voltage regulator, just above the power brake booster.
Thanks.
Old Aug 2, 2010 | 05:54 PM
Starfire1961's Avatar
Vacuum Diagram
Does anyone have a diagram for all the vacuum lines for '61 Starfire showing where they all should go? Thanks
Old Aug 3, 2010 | 04:05 AM
chequenman's Avatar
vacuum
I hope you have a Service Manual it should support your questions with the answers!
john116
Dec 7, 2014 01:51 AM
hueveaj
Oct 29, 2013 12:53 PM
Johnnykick
Oct 18, 2012 05:22 PM
clinton70
Jan 31, 2010 02:53 PM
js_specials
Aug 19, 2006 09:53 AM
