wheel size for disc brakes 71 cutlass
Old Jan 4, 2009 | 05:45 PM
iuhoops83's Avatar
I purchased an original disc brake assembly from a 71 Cutlass Supreme for use on my 71 Cutlass S that has original drum brakes. Can I use my 14 inch SSII wheels or do I need 15 inch when I make the conversion to disc? Also, can you use 15 inch SSII or SSIII wheels on a 71 Cutlass?
Old Jan 4, 2009 | 06:32 PM
cts-v's Avatar
14's should work.
I had 14 inch wheels on my 70 Cutlass Supreme, and it has factory disc brakes. I think the rotors and calipers are the same on the 71 as well.
Old Jan 4, 2009 | 06:41 PM
14" wheels were factory standard with disk brakes. The factory calipers and brackets WILL clear all factory 14" wheels. All bets are off for aftermarket conversions.
Old Jan 5, 2009 | 11:10 AM
kaz442's Avatar
Joe correct me if I'm wrong but didn't some of the 14" steel wheels not fit disk brake applications? Only front drum. Jkaz
Old Jan 5, 2009 | 03:03 PM
In the 1960s there were some factory wheels that had a different backside contour and thus only fit drum brakes. There were also 14" wheels that did clear the disc brakes. My point is that you do not need 15" wheels to clear FACTORY disc brakes on an A-body car, but as you correctly point out, you DO need the correct disc brake 14" wheels. Note that all 14" SSII/SSIII wheels do clear factory disc brakes. The SSI wheels come in two flavors - drum only and disc brake compatible.
copper128
Aug 31, 2021 09:56 AM
steve walker
Jun 21, 2014 06:17 AM
steve walker
Feb 6, 2013 07:25 PM
willz64
Brakes/Hydraulic Systems
Apr 29, 2010 11:48 PM
speedy_87ss
Oct 23, 2009 08:35 PM
