Trans cooler fittings mismatch
I bought the ToughOne 433322 radiator and it turns out my trans cooler line fittings are smaller than the adapter on the radiator.
Anyone happen to know the correct brass adapter size for this application?
This is out of the radiator. The female end is supposed to accept the trans line but it's too large. The male and needs to remain the same size as it threads into the radiator.
[IMG][/IMG]
[IMG][/IMG]
are you sure the radiator is an inverted flare fitting?
The adapter you show does not show the small end but from what I see it may not be inverted flare like your tubing, thus the need for an adapter.
Just get the right-size-hole adapter from the auto parts store near you, if need be.
bjtstarfire
December 13th, 2008 08:48 PM
