licence plate bracket
Old Jul 9, 2014 | 08:09 PM
Macadoo's Avatar
My CS doesn't have a front bracket. Doesn't look as if it ever did. This is the only style I can find that looks like it will fit. But I don't have holes in the bumper and I don't want to drill if there is another option.
[IMG][/IMG]
Old Jul 9, 2014 | 08:25 PM
mrolds69's Avatar
No, that's about it, that's the right bracket. If you put the plate on the bracket and fasten the top, you can use the bracket holes for a template. My Olds is a few hours away, I don't remember drilling, but I did buy a bracket. If you buy a license plate frame, a metal one, you can probably get away w/o the bracket. You could also stiffen the plate more by backing it with sheet metal. The plates now are really flimsy.
Old Jul 10, 2014 | 08:42 AM
tds's Avatar
tds
Do you really need the front license plate on a 1971 classic? Is the law "enforced"?
Pretty lucky in Texas. I've been stopped once, but the officer admitted he really just wanted to see the car.
Old Jul 10, 2014 | 11:04 AM
RandyS's Avatar
If it's regustered as a DD, it needs to comply with the laws of your state. If it is registered as a 'classic', then it's usually just a rear plate - YMMV.
Old Jul 10, 2014 | 11:53 AM
RetroRanger's Avatar
72 Olds CS
my 72 has two holes at the right spacing for the front plate. I put a ~1/2 spacer between the plate and bumper and mounted the plate right to the two holes. The spacers keep the plate from rattling/vibrating/buzzing against the bumper and the plate sits at the same angle as the bumper.
Old Jul 10, 2014 | 03:31 PM
Macadoo's Avatar
Yeah, it's registered as a DD, which was the plan when I started this build. Not so much the idea now...not after all this work! Lol.
Retro, what did you use as a spacer?
Old Jul 10, 2014 | 03:45 PM
72 Olds CS
Justa couple round plastic parts to set the plate away from the bumper....intially the plate would rattle against the bumper so I added the spacers...I just checked I dont have any good (or bad) pics handy but IIR Ill snap one
Old Jul 10, 2014 | 08:48 PM
Macadoo's Avatar
Don't bother dude, I think I get it. But thanks anyway. I think i have some thick rubber washers laying around.
Old Jul 11, 2014 | 08:22 AM
KDV's Avatar
KDV
My CS is the same way. The front bumper has the indentations for the holes but they're not drilled. It's not my daily driver, so I just left it as it is.
I'd like to see a pic of yours once it's completed.
Old Jul 11, 2014 | 09:52 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I prefer the non plate look too. When I get pulled over I just state that its originally a cali car that never had a front plate and Im waiting for someone to reproduce the bracket. Hate front plates!
Old Jul 11, 2014 | 06:00 PM
Macadoo's Avatar
I'm not sure I could get away with that around here. Illinois is kinda' broke so tickets are hard to get out of
Old Jul 11, 2014 | 06:08 PM
I'm noticing a theme here. Some front bumpers with holes for the license plate and others without. My car has it's OEM bumper (re-chromed) and the holes for the license plate bracket are not only there, they're threaded so the bracket gets fixed on nice and tight. Use nylon plugs in the bracket to attach the plate (just like the rear plate attach) and you're good to go with no vibration or rattling.
I got an OEM license plate bracket from Eric Jensen (jensenracing77) a while back. It was a bit on the rusty side but I cleaned it up and got it looking like new again. It's the exact same pattern as that repro you posted. That looks like the one on ILT's website. In advance - these things are not strong - they're rather flimsy even from GM.
Old Jul 11, 2014 | 08:56 PM
Macadoo's Avatar
I'm just hesitant to drill holes in my bumper but I don't see any other option.
Old Jul 12, 2014 | 10:38 AM
Use some tape on the chrome to help prevent tearout on the chrome. When you're done the drilling, use a tap/die set to ream the threads you want in the hole.
Old Jul 13, 2014 | 06:13 AM
Macadoo's Avatar
Ahh, an old woodworker's trick. Good call.
Old Jul 13, 2014 | 05:14 PM
sammy's Avatar
Sammy70 455 Supreme
haha...I did not even know that these cars came with a front bracket...
Old Jul 13, 2014 | 05:25 PM
501Paratrooper's Avatar
By the way anyone have a used bracket to sell?
Old Jul 13, 2014 | 06:56 PM
Does your bumper have the upper license plate holes? If so, just use those. My Olds Club license plate has been attached with just those two for ~15 years now. Prior to that its Texas front plate was there for who knows how long - 20 years? Both with no issues.
Old Jul 16, 2014 | 02:22 PM
Macadoo's Avatar
Dang sammy, I still love that silver!
Nope, no holes whatsoever. But it does now. I used the tape trick and it worked like a charm. Tapped the holes and added a couple of rubber washers and I now have a front plate.
Thanks everyone.
Old Jul 17, 2014 | 08:46 AM
Put grease or paint around and in the holes you drilled to prevent rust and the chrome from peeling.
Old Jul 17, 2014 | 06:52 PM
Macadoo's Avatar
Good idea. Thanks Doc.
Olds442redberet
Jan 26, 2014 08:53 AM
AirborneRME
Mar 8, 2013 08:04 PM
442much
Jun 1, 2012 05:46 PM
Satellitecentral
Oct 6, 2009 05:46 AM
442much
Jan 21, 2009 07:41 PM
