Left rear quarter window
My left rear quarter window will not go up correctly/straight while I turn the window crank, I need to grab the window and pull it up to help it while turning the crank.
Do I need new rollers? Does anyone know what the fix is?
Brother I'm going through the same thing on the 64 F-85 Pro-Touring build. One rolls up and down fine, even have the access panels open for comparison's and still cannot figure out why that one-(drivers side)-does not work right. I have the chassis manual too! Got a second pair of eyes coming over this weekend and if we can figure it out I will look up this post.
I just pulled the rear windows and regulators out of a '70 442 and immediately noticed the lack of lubrication on the rollers and guides. as long as the regulator gears are not stripped, a good lubing with grease of all the contact areas will probably solve the problem. Hope this helps.
Not the problem. When cranking the drivers side, the rollers and regulator is well lubed and in place, the glass will not stay on track-this is a post car. I use the pass side as an example and still cannot figure it out. But for now I'm more focused on getting the car started and tuned-and now its blazing hot out to boot.
rocket88philbaker
February 2nd, 2013 12:50 PM
1k442
May 10th, 2010 11:30 AM
