heater confusion
Old Feb 22, 2011 | 09:29 PM
whojohnjones's Avatar
heater confusion
I have a 1983 buick park avenue and I cant get
my heat to work at all. my heater blend door
works and the heater core gets hot there is no heater valve and has
good flows so I am confused. . and my vacuum
doors only open in ac mode should they work in
heater settings also
Old Feb 23, 2011 | 05:47 AM
Lady72nRob71's Avatar
I assume this is not an auto temp control system...
Sounds like the vent directional door is not opening on heat (it should). The one that selects panel, defrost or heater.
Check the vacuum line coming from the engine bay for breaks or cracks, but if the AC part is working, then it is prolly okay.
This could easily be the mode vacuum switch on the control panel. Can you 'jiggle the (mode) handle" and get it to work? The mode switches should be available at Rockauto...
Old Feb 24, 2011 | 02:56 AM
Yellowstatue's Avatar
There is a vacuum control on the heater case, which is accessable after you remove the glove box-straight above the passenger's left foot- I think this is the control that I changed when I was having heating problems...round black diaphragm with metal links and a small vacuum hose...try that...
Old Feb 24, 2011 | 05:15 AM
You can pull the little hose off, connect with a section of clean hose, suck on it, and see if it moves and does not lose vacuum.
Old Feb 24, 2011 | 03:16 PM
the switch that controls the vacuum was bad and the parts store sold me a universal style heater core that wasn't functioning enough fixed those and I'm ok now first time having heat in 3 years in this car thanks
Old Feb 25, 2011 | 02:55 AM
So the cold weather will be over soon and you will be complaining about the heat...
Lady72nRob71
Oct 8, 2013 07:16 PM
Moto
Mar 7, 2011 04:44 PM
1966_F85
Feb 15, 2011 05:15 AM
jag1886
Oct 15, 2010 12:06 PM
yeahbuddy
Aug 19, 2010 01:15 PM
