Door strikers
Old Feb 26, 2016 | 11:55 AM
Marx3's Avatar
Door strikers
does anybody know what type of strikers a Delta 88 from the late 70's and the early 80's use?
Do they use the same metric strikers as other B-body cars of the same era?
Does anybody know where to buy these strikers?
Old Feb 26, 2016 | 01:48 PM
Well, the Delta 88 IS a B-body, so I'm going with YES. I suspect they are the same on every B/C/D and G-body car from that timeframe.
Old Feb 26, 2016 | 09:22 PM
Marx3's Avatar
Yes you would think so, but it seems that all other bodies are using 7/16 thread strikers. The b-body got metric strikers, for some reason. Problem is, that no one carries them, it seems. This is pretty odd, since the Delta and especially the caprice/impala was produced in such large numbers...
What to do :-)
Old Feb 27, 2016 | 06:17 AM
Octania's Avatar
run your favorite tap thru the hole and use what fits?
Old Feb 27, 2016 | 07:30 AM
Marx3's Avatar
Haha, well that could propably work.
I might look into running a 7/16 tap through an M12 thread and try how much torque it will stand.
I just can't believe no one makes replacement striker for cars that was mass-produced like this!
Old Feb 28, 2016 | 02:01 PM
They DO make strikers for these cars. The thread is 7/16-14. I just pulled one of the strikers from my 84 Custom Cruiser. It's 7/16-14 - I checked it with my thread checker set:
I'll also point out that the bolt easily threaded into the M12-1.75 gauge also, by the way:
Old Feb 28, 2016 | 02:09 PM
FYI, the 7/16-14 threads have a 0.4375" major diameter and 14 threads per inch.
The M12-1.75 threads have a 0.472" major diameter and 14.5 thread per inch. If the striker bolt from my 84 were really metric, it would not have threaded into the 7/16 gauge, since the M12 bolt is slightly larger in diameter.
Old Feb 28, 2016 | 10:54 PM
Marx3's Avatar
Thank you very much for taking the time to actually look into this.
If you '84 b-body has 7/16 threads, then my car must be a special deal. Maybe it's because it is an export model, I don't know. So your 7/16 striker went into the M12 gauge easily... Interesting. :-)
Old Feb 28, 2016 | 11:08 PM
Marx3's Avatar
I just checked a couple of websites that supply parts for these cars. Rockauto clearly has strikers for b-body up to '76 and from '80 up.
It seems they ran 1/2" threads up to '76, had a couple of "dark" years with metric threads from 77-79 and then went to 7/16" threads in '80.
Old Feb 29, 2016 | 06:27 AM
It would be EXTREMELY unlikely that GM went from SAE to metric and then back to SAE threads. The conversion has only been one way. Also, RockAuto is NOT a factory parts book and their on-line catalog is full of documented errors. I don't put much stock in it. Try ordering Oldsmobile motor mounts from them...
How are you so certain your striker bolts are M12? Have you tried screwing a 7/16-14 bolt into the threads in the jamb? Since 7/16 is smaller than M12, it should be loose if the threads are really M12.
Old Feb 29, 2016 | 06:37 AM
Marx3's Avatar
You are absolutely right, it don't make much sense. I measured my striker with a gauge plus I held it up against an M12 bolt. The threads fit together like a glove.
I know the Rockauto catalog ain't necessarily the truth, but I can't find strikers for 77-79 B-body cars anywhere else either. Plus I have heard it from people driving Caprice, that it's a fact that 77-79 had metric strikers.
Here is a link for the striker. Try the OE replacement number...
the results are for 77-79 cars only.
Old Feb 29, 2016 | 06:40 AM
And as I pointed out in Posts #6 and #7, 7/16-14 and M12-1.75 threads are EXTREMELY close dimensionally. One more time. Get a 7/16-14 bolt and see if it threads into the door jamb threads. I've got $10 that says it fits perfectly.
Old Feb 29, 2016 | 09:27 AM
Marx3's Avatar
You're on :-)
I'll report back as soon as I have checked. I am really crossing my fingers that my friend was wrong.
Old Mar 23, 2016 | 05:59 AM
Marx3's Avatar
Sorry for the delay. Finally bought a 7/16-14 UNC bolt to try and run into the threads for the striker.
It actually screws into the threads in the pillar, but it is not an exact fit.
I bought an M12-1.75 striker for a Chrysler to try it on.
Went right in but the head that catches the door lock is thinner than it should be., so it's no good.
Here is the 7/16-14 bolt compared to the M12 striker from the car
They are obviously not the same.
I guess this concludes that there just might be some truth to this mystery: the 77-79 B-body cars use M12 strikers for reasons unknown.
At least my car does :-)
I guess the good news is, that I might be able to get away with installing 7/16 strikers in the M12 hole.
Old Mar 29, 2016 | 08:00 AM
Inline's Avatar
Hi-jacking the thread. I have new strikers to replace worn ones, but have an maybe stupid question. Do i need to remove interior panels to change them ( to hold the nut) or were they wise enough to build an cage for the nut behind b-pilar to hold it so i can just screw old striker out and new in?
( yes i will mark the position of old striker to b-pilar).
I ask because i dont want to remove any interior plastic if its not necessary just to see if it was or not, since theyre so brittle already.
Thank you.
Old Mar 29, 2016 | 09:24 AM
Marx3's Avatar
no need to disassemble anything. The striker screws right out and right back in.
Old Mar 29, 2016 | 09:38 AM
Inline's Avatar
Great, thanks alot.
Old Apr 19, 2024 | 03:36 PM
clevertymez's Avatar
Door strikers nut interchangeable
Are you able to change the door striker nut? The vehicle in question is a 1983 Oldsmobile Delta 88. You know, some are 7/16" - 14 & M12 - 1.75.
70Post
Jan 7, 2016 08:09 PM
ostie13
Oct 17, 2015 05:20 AM
dancutlass
Jul 14, 2012 06:58 PM
charlierogers
May 21, 2011 07:18 AM
Allan R
Apr 25, 2011 09:56 AM
