Charcoal canister delete
Old May 6, 2011 | 06:10 AM
texasred's Avatar
Tom Servo's Stunt Double
The car is a 71 Cutlass Supreme 350. If I delete the charcoal canister and plug the line to the standpipe, am I creating a pressure problem (positive or negative) in the tank? Should I change to a vented fuel cap? If so, suggestions on a P/N or suitable substitute?
TIA
C.J.
Old May 6, 2011 | 07:13 AM
Lady72nRob71's Avatar
I would say yes - you would need a vented cap, as normally the vent would be through the charcoal can. Do not have part #'s though...
Old May 14, 2011 | 01:58 AM
texasred's Avatar
Has anyone used a vented fuel cap on a 70-72 vintage Cutlass? I figure it "might" leak with a full tank, but I'd like a confirmation one way or the other.
Thanks in advance.
C.J.
Old May 14, 2011 | 04:28 AM
There's no reason why a vented cap should leak, in and of itself. I can't say for sure whether the filler neck is any different where the cap seals, but I don't think it is.
Getting the right cap should be no problem - just look one up from an earlier car and confirm that it's different from the one shown for your car.
Remember that it is technically illegal to modify or disable any emission controls, so don't do it if you're in a locality where they do emissions inspections (mostly in the more Fascist states, like CA and NJ).
Old May 14, 2011 | 06:04 AM
bonnevillegreg's Avatar
Uhhh...well, actually...
Out here in "fascist" California, model years 1974 and older are smog exempt and don't require inspections for registration purposes.
rhett838
Jul 24, 2015 12:23 AM
oldzy
Jul 1, 2013 06:55 PM
jbestic
Mar 26, 2012 08:02 PM
frasco
Aug 1, 2011 09:25 PM
esisson
Nov 23, 2008 10:05 AM
