bad gas
Old Mar 19, 2009 | 02:03 PM
scrappie's Avatar
bad gas
Whats the best and easiest way to get old gas out of a 71 442 conv's tank and lines?
Syphon? pump?
Car has not run in 3 yrs.
Old Mar 19, 2009 | 04:47 PM
bjtstarfire's Avatar
disconnect the rubber gas hose leading to the carb and direct it to a container (extend if needed). Take an air compressor and rags in a plastic bag, put air hose into tanks filler pipe block off with rags in a bag, and slowly build up the air pressure (not much is needed) and all will be done in no time.
Works like a charm and no mess.
Ben
Old Mar 19, 2009 | 04:53 PM
jensenracing77's Avatar
second the above answer. it don't take much pressure.
kfzr2
Aug 4, 2015 05:11 PM
odddoylerules
Apr 21, 2014 07:54 AM
airmale
Nov 13, 2013 11:15 AM
442scotty
Aug 9, 2011 12:32 PM
berto
Aug 4, 2006 10:46 PM
