Add power to my 95 cutlass ciera?
Old Aug 7, 2007 | 02:01 PM
pearldawg23's Avatar
Anyone know of a way to add power to my 95 cutlass ciera sl? Any power increases would be helpful and I'm willing to spend some decent money on it because I intend to keep this car for a long time.
Old Aug 8, 2007 | 10:56 AM
This body style had the Buick V6 available as an option. A supercharged 3800 can be installed with a lot of work.
Old Aug 8, 2007 | 06:41 PM
Redog's Avatar
Which motor?
Old Aug 9, 2007 | 09:18 AM
sorry, it's a 3.1 liter v6....wasn't thinking when I made the thread obviously
Old Feb 5, 2008 | 08:18 PM
1991droptop's Avatar
If its got the 3.1 liter, then the 3.8 liter should fit in there to, and of course the supercharged one would be the best bet. Let me know how it goes, because I am currently looking for a 3.8 supercharged for my 91 Supreme convertible.
Old Feb 13, 2008 | 07:18 PM
occupant's Avatar
Occupant Ilied Industries
3.8SC is an easy bolt-in but will probably require a lot of wiring work to make right. You'll also likely need a better fuel pump and stronger motor mounts and axles. Transmission could use freshening as well.
Want more torque, comparable horsepower? Try the 4.9L Cadillac FWD V8, available in 94-95 DeVilles that didn't get a Northstar motor. Will require some fabrication to fit motor mounts and accessory brackets. Try Fiero forums for information on these swaps. Also I have been told Silhouette/TransSport/LuminaAPV engine cradles and axles are very easy to swap into an A-body like a Ciera. Sway bars front and rear are also good parts to grab as well as rear disc brakes. Buy a whole van (bad motor/trans) for $400-$600 or so, grab what you need, scrap the rest, use the money from the scrap to get your Caddy V8, spend a few hundred on brackets/mounts/wiring, and have serious power on a low budget.
Old Feb 14, 2008 | 05:08 AM
Oldsguy's Avatar
Past Administrator
My family driver, a '99 Buick LeSabre has a factory re-manufactured 3.8 in it that is pretty solid for a V6. About three months after I bought the car (used) the engine blew up, no.3 rod bearing went south and lost oil pressure. I paid for the re-manned engine and have been happy with it since. I think they are pretty good engines and your car is smaller than the LeSabre so you should feel it even more.
fennjones
Jan 30, 2015 12:58 PM
nj_cutlass72
Jan 2, 2013 09:19 AM
Rickman48
Apr 3, 2012 09:50 PM
Keieljun
Suspension & Handling
Feb 5, 2009 09:27 PM
Big Dave
Dec 15, 2005 12:02 PM
