68 Cutlass / Offset Radiator Core Support?
Hey guys, was wondering if anyone could lend some expertise on something that I'm a little confused about on a 1968 Cutlass.. Are your top on your top radiator core supports offset toward the fan? hence creating a slight angle on the radiator? ( so the top of the radiator is leaning back toward the For the of me I can't figure out what I am dealing with here.. I have had the car since 97' and have driven it this way since then.. Matching numbers car, came with the original hub caps, radio, original spare tire, jack.. the whole 9... Wondering if the top core support is not OG, or if it's the radiator that is not OG. When I had the radiator out and to a recently to be cleaned and tested the guy there def says its the right period for GM given the various markings etc on the radiator. Any advice / help would be appreciated. (ps. the fan / shroud / radiator do not rub or interfere with the fan with this odd offset just to be clear / it's a slight angle
jensenracing77
January 25th, 2018 04:16 PM
adamjana88
September 2nd, 2015 06:04 PM
