68/69 Cutlass Speedo Faceplate/needle RnR
Old October 6th, 2010, 12:10 PM
STOP call'n it a Chevelle
arodenhiser's Avatar
Can anyone tell me how to remove the needle on a 68/69 Cutlass/442 speedometer. I want to switch the face plates so my dash looks like an original console/floor shift. I have been warned not to pry on the needle because the internals are easy to break. Thanks
Adam
arodenhiser is offline
Old October 7th, 2010, 11:26 AM
Lance
ROCKET VAPOR's Avatar
Send your gauge to John at Redline Clock and Gauge Repair. He will swap out your speedometer face for a floor shift gauge face. He does great work for cheap, and has a fast turn around.
http://www.redlineg.com/
I believe you can pull off the needle, but pressing it back on might be what would get you in trouble.
ROCKET VAPOR is offline
Old October 7th, 2010, 07:13 PM
I gave John a call. He seems like a teriffic guy. I told me to carefully take the needle, turn it counter clockwise below 0 mph. With a little pressure keep spining it backwards and pop, off it came. I changed the plate and turn signal light tubes. To put the needle back on he recommended to point the needle at 12 o'clock and press down and clockwise until it hit zero. Everything went well. Just as he said. Thanks. He never once mentioned to send it to him because it is to easy and quick. If you need any clock, speedometer or other guage work I would definitely give he a call.
Adam
Old October 8th, 2010, 05:35 AM
Lance
Originally Posted by arodenhiser
I gave John a call. He seems like a teriffic guy. I told me to carefully take the needle, turn it counter clockwise below 0 miles per hour. With a little pressure keep spining it backwards and pop, off it came. I changed the plate and turn signal light tubes. To put the needle back on he recommended to point the needle at 12 o'clock and press down and clockwise until it hit zero. Everything went well. Just as he said. Thanks. He never once mentioned to send it to him because it is to easy and quick. If you need any clock, speedometer or other guage work I would definitely give he a call.
Adam
Awesome!!!
He really is a great guy. I had him restore the whole gauge cluster in my '70 Chevelle SS and the tic-toc-tach in my '70 442. Both times he had a very fast turn around (about five days) and was very reasonable with his charges.
Old December 28th, 2010, 08:10 AM
68vaolds's Avatar
How much did he charge to restore the whole guage cluster?
68vaolds is offline
Old December 28th, 2010, 08:20 AM
Lance
IIRC, around $200.00 for the tic-toc-tac and about $500.00 for my '70 Chevelle SS complete gauge cluster.
Call John and talk with him. He is a great guy and will take the time to very clearly explain all steps in great detail.
731-571-0766
http://www.redlineg.com/redlineg/Welcome.html
Old December 28th, 2010, 12:12 PM
68vaolds's Avatar
Thanks for the info.
68vaolds is offline
Old December 28th, 2010, 12:13 PM
68vaolds's Avatar
Adam, where did you find the other faceplate?
68vaolds is offline
Old December 28th, 2010, 05:10 PM
I bought a whole used speedo from a user here. Put a parts wanted ad out and I am sure someone can find you one.
I think the faces are being reproduced. I checked... OPGI has them p/n C240555 or look at the link here...
http://www.opgi.com/product.asp?catm...odCode=C240555
I got the speedo cheaper than this and free pick up. If you look around I am sure you can find the repos elsewheres too.
Adam
Old December 29th, 2010, 09:12 PM
68vaolds's Avatar
Thanks for the link,I'll have to check for other suppliers.
68vaolds is offline
R_CK_R
August 18th, 2014 08:59 AM
Sampson
February 10th, 2014 07:53 PM
Gene442
December 1st, 2011 08:53 AM
crazy'boutOlds
August 10th, 2010 06:33 PM
wolfman98
November 11th, 2009 05:01 AM
Quick Reply: 68/69 Cutlass Speedo Faceplate/needle RnR
