55 horn
Old Feb 25, 2007 | 09:37 PM
troberts6
Guest
Posts: n/a
Question 55 horn
I have a 55 Olds 88 and my horns do not work. I tried taking a wire from the battery straight to the horn itself but nothing happened. So i need to get some new horns. I've been looking around and can't find anything. Anyone know of anywhere i can find some?
Thanks for any help
Old Feb 25, 2007 | 09:44 PM
2blu442's Avatar
I don't, but be sure you have a good ground on the horns before deciding they're bad. I've used my battery charger on a horn off the car to test them and if I don't have a good contact with the negative clip it won't make a sound. John
Old Feb 25, 2007 | 09:53 PM
troberts6
Guest
Posts: n/a
So I should take a battery charger and just hook the positive to positive and ground to negative and this will be the positive answer?
Old Feb 25, 2007 | 10:02 PM
2blu442's Avatar
That's what I'd do. You've already run the hot wire to it and ruled out a break in the positive side. But if there's rust or corrosion interfering with the ground, you may not be catching that problem. Just a thought. John
Old Feb 25, 2007 | 10:07 PM
troberts6
Guest
Posts: n/a
Cool thanks. Also do you know what kind of oil filter it would take?
Old Feb 28, 2007 | 05:42 PM
Tedd Thompson's Avatar
troberts6, If your engine is stock and a after market spin on type filter hasn't been added you can get a filter at any Napa store.I use their gold filter #1121. works for me and my 55 S88. Tedd
Old Feb 28, 2007 | 09:45 PM
troberts6
Guest
Posts: n/a
Thank you Mr. Thompson.
Also, 2blu442 I tried to do what you suggested with the wiring for the horns, and I can't figure it out seeing as how there is one wire that runs from the horns to the horn relay. The shop manual I have says to take the horn apart and test it but I can't figure out what kind of screws are holding them together. There is also a selant type thing on the horns so I'm not sure if I should be messing with them untill I can find out what this stuff is.
Old Feb 28, 2007 | 10:07 PM
2blu442's Avatar
The single wire is the hot wire, and it'll have some sort of gasket around the fork. Then the housing is grounded to the car through the mounting bracket. I attached the positive clip to the fork, then the negative clip to the mounting bracket, and heard a squawk out of the horn. John
Old Mar 1, 2007 | 04:58 AM
Oldsguy's Avatar
Past Administrator
The hardware on the horn body could be rivets not screws and the horns may be rusted up so they don't work. If you can find a way to disassemble them it might be worth it since you have a manual to help you out. For what it's worth, unless you are looking for all original and simply MUST have those exact horns; why not just take a trip to the local junk yard and pick up a couple from any big sedan from the sixties or seventies? Most of them had good, deep sounding horns that would be appropriate for your '55. A horn is about as generic an item as you can get, especially if you stay with a GM item and they all work on 12 volts.
Old Mar 1, 2007 | 12:45 PM
American Lead's Avatar
2Blue 55
personally i like the nice squak that comes out of the horn on my 55. www.allamericanclassics.com has a 55 oldsmobile 4dr holiday that may have a horn, along with ebay, you see some sellers with a car that they are parting out, the horn may not be on yet, but if you shoot them an e mail they would probably post it up for you.
Good luck finding your parts
Old Mar 1, 2007 | 04:30 PM
troberts6
Guest
Posts: n/a
Thanks guys for the help.
joepenoso
Jul 12, 2013 11:03 AM
DennisG.
Apr 15, 2012 11:01 AM
hammer
Jun 22, 2007 07:10 PM
orange442
May 14, 2006 03:06 PM
orange442
May 14, 2006 03:03 PM
