1977 Procharged 355 Cutlass
FOR SALE: One of a kind 1977 Oldsmobile Cutlass. Garage kept, red paint tri coat, body is in excellent condition with NO dents or rust. Fiberglass front & rear bumpers, fiberglass hood. INTERIOR: Black bucket front seats and black bench rear seat in great shape no rips or tares. Also new carpet. Centerline wheels, 15x7 in the front and 15x8 in the rear. Wrapped headers with 2- 1/2" exhaust with 2- 1/2" turbo mufflers and H-pipe. Autometer boost,water temp,oil press, trans temp, fuel guages. Automter speedo and tach replaced in stock locations
ENGINE: 355 small block Chevy
> Pro charger P600B supercharger billet impeller 9 lbs
> MSD6AL ignition BTM Control
> Holley 750 AED Boost Carb
> Braided Line throughout
> Edelbrock 110 GPH fuel pump
> 7qt oil pan
> ARP studs (heads and mains)
> Eagle 4340 steel crank
> Eagle 4340 H beam 6" rods
> Balanced assembly
> SRP pistons forged flat top
> Moly rings
> M55 oil pump
> Hydraulic Comp cam
> Aluminum Radiator, electric fans
> Sportsman II Heads
> 2.02/1.60 stainless valves
> Dual springs
> 72 cc straight plug
> 1.6 aluminum Harland Sharp rollers
> Edelbrock Performer
TRANSMISSION:
> TH 400
> Fully automatic
> Kevlas Clutches
> B&M holeshot 3000 (2800 to 3200 10" stall)
> 168 tooth flexplate
> Mini starter
REAR AXLE:
> 9" Ford
> 31 spline
> Power trax automatic diff
> Vented rear disc brakes
> 1/2" wheel studs
Car is super clean inside out from top to bottom, alot of detail and time in this car. Looking for 12,900 or trades
http://www.collectorcarnation.com/Cu...html?aid=32795
> 7qt oil pan
> Balanced assembly
> Moly rings
> M55 oil pump
> Hydraulic Comp cam
> Sportsman II Heads
> Dual springs
> 72 cc straight plug
> Edelbrock Performer
TRANSMISSION:
> TH 400
> Fully automatic
> Kevlas Clutches
> 168 tooth flexplate
> Mini starter
REAR AXLE:
> 9" Ford
> 31 spline
> 1/2" wheel studs
Dec 10, 2011 07:49 AM
