DMV Plates and Records From Back to 1979 milage 61,689 was then NOW 61862
NEW BRAKES
NEW TIRES on 1970 DATE CODE AZ 15x8 Rally Wheels Maint. Record Book Shows; Carb Work Exhaust Work mufflers are Pace Setter Replaced frost plugs 300 Horsepower 350 Engine Code CTD 350/300HP (4-Spd) Muncie 4 Speed with correct shifter Power Steering Replaced Radiator and Fan Shroud Replaced Fuel Pump
Car Has Not Many Options; AM/FM Radio Manual Disc Brakes Manual Top and Windows NO A/C NON AIR Car 982 Code Donnybrook Green / Tan interior / Black Top Just out of long term storage. Time capsule. Tires are old Bias ply Mach Sixty and Mach Seventy on Keystone Klassic Wheels , same as it has been since 1979 when the car was parked most of the time. NEEDS Brake work. I did drive the car home in June 2024. VIN number on the block matches car ID and Title ( In My Name , No Leins , Clean ).
INFO ON 1970 Corvette Total Production: 17,316 Coupe: 10,668 (61.61%) Convertible: 6,648 (38.39%)
Selling now AS IS $$35000Cash US Dollars. No Trades Thank You.
Located near Osseo MN 55369
Hagerty Insurance Agreed Value is $50,000
