Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
vortec 5700 & trans into 78 cutlass w/260
Old Nov 24, 2011 | 04:36 PM
jjamm7667's Avatar
I've been trolling this site for a while and there's tons of good info and intelligent olds guys here. I have a 78 cutlass w/260 and i want to put my 2000 vortec 5700 & 460 trans into it. I have the complete harness, cpu, fuse box, frame & motor mounts.
What's a good starting point? Be gentle ...I'm new.
Old Nov 25, 2011 | 04:36 AM
garys 68's Avatar
Was the old Gen II SBC offered in 2000? I know the Gen III 5.3s and 6.0s were available from 1999.
Old Nov 25, 2011 | 06:34 AM
jjamm7667's Avatar
It's a gen II. 5.7
Old Nov 25, 2011 | 07:32 AM
gearheads78's Avatar
car guy
Tahoes, Suburbans and 3/4 ton crews went to 2000 with the 5.7 and vans still had them until at least 2002
Old Nov 25, 2011 | 09:16 AM
jjamm7667's Avatar
It came out of a Chevy express 1500
Old Nov 25, 2011 | 11:29 AM
garys 68's Avatar
Huh...learned something new.
Fitment should be like any SBC.
Do you know if it has the reverse cooling and Opti Spark like the LT1s? And does it have electronic auto trans controler in the ecu?
What trans are you planning to use? The Olds trans may or may not have dual POB/SBC bolt patterns.
Old Nov 25, 2011 | 11:44 AM
car guy
It will be an R motor. Basicly all regular SBC rear distributor Vortec headed motor.
Old Nov 25, 2011 | 12:46 PM
jjamm7667's Avatar
Thanks guys for responding so quickly. Garys 68, if you are referring to the R in the vin you are correct. I am using the 460 trans thats withg the motor.
Old Nov 25, 2011 | 01:21 PM
car guy
If it was me I would just carb that thing. The poppet valves injectors are known for trouble trouble when they are up there in miles. There is a kit to replace with electronic injectors but its about $700.00
Also if you do reuse the injection intake make sure to replace the intake gaskets now before you put but in. It WILL leak and it always start as a internal leak inside the motor .
Old Dec 28, 2011 | 04:00 AM
panos's Avatar
The vortec 5700 is the last gen I made ,also called L31 made until 2002,i just put one in my car,carburated though with alum.heads.
getitmann
Aug 18, 2013 06:44 PM
leetownreb
Jun 7, 2013 10:32 AM
78ChevOlds
Aug 27, 2010 10:31 AM
Jannebill
Aug 25, 2010 06:31 PM
2blu442
Nov 11, 2008 05:38 AM
