Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
65 F85 Buick 455
Old Mar 23, 2017 | 05:37 PM
Tim Van Lehn's Avatar
65 F85 Buick 455
Hi I was wondering if a 455 would bolt in place of my 330? I have a 65 330 with the 2 speed. I'm new to this so I hope this isn't a stupid question. Thanks
Old Mar 23, 2017 | 05:57 PM
oldolds88's Avatar
welcome to the site. no such thing as stupid questions. a buick will bolt to your trans,the motor mounts are different ,so get the frame mounts for the buick and they should bolt on the cutlass frame, exhaust is different, headers from a skylark of the same year should work, then just your little bugs like wire harness,which will have the same ,oil,water and alt set up but maybe different location. don't know if anyone on here has done this swap. but I'm sure its been done. where are you located?
Old Mar 23, 2017 | 06:43 PM
I'm in Charleston WV. The 455 I believe the s out of a 70 Buick the owner is running that down for me now. I appreciate your helpful comments
Old Mar 23, 2017 | 06:44 PM
also thanks for welcoming me to the group
Old Mar 23, 2017 | 07:22 PM
marxjunk's Avatar
You need 67GS 400 frame mounts and oil pan and exhaust manifolds or equivalent...
They are all special and expensive,,,the 67GS. Rubber mounts have been discontinued for decades and are rare and expensive..67 uses a specific exh manifold on one side too.. but all can be gotten around
T A performance makes special frame mounts that use the easy to get 68 and up style rubber mounts,,oil pans are easy too aftermarket..but 67 specific skylark manifolds are tuff to get and headers are very expensive..
It all adds up to big money...
Old Mar 24, 2017 | 04:27 AM
where is the best places to look? Also does anyone sell quarter panels and other body parts?
Old Mar 24, 2017 | 06:41 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I say put in a slightly upgraded 2004R with 2000+ stall, 3.55 or 3.73 posi and you will gain mileage and power off the line. Add a custom 76-80 800 cfm Qjet and bracket for the 2004R trans and have the best of both worlds. As Joe pointed out 1.76 first gear just blows.
Old Mar 24, 2017 | 07:41 AM
It sure looks like I came to the right place. I'm still looking for body parts as well. Are there good after market suspension parts available and if so what do you recommend?
Rick nesthus
Aug 25, 2013 09:05 PM
ralsy
Jun 30, 2012 04:22 PM
Jayycobb
Drivetrain/Differentials
Dec 6, 2011 07:27 AM
Jetfire63
Jul 5, 2011 11:33 AM
