Issues With 68/98 rear end
Old October 18th, 2014, 12:24 PM
cameron_zank's Avatar
I recently acquired a barn car from my uncle. It's a 1968 98. The rear axle wont budge. I haven't taken anything apart yet, but the shifter indicates that the car is in neutral and the trans seems to be shifting as well. I will note that my uncle has no idea where the ignition key is. But seeing that the ignition is on the dash, I assume that there is no "lockout" being that I don't have the key but the car is still seeming to shift gears. So, my question is, is the rear end locked up? Has anyone ever had this happen? Everything on the car is completely stock.
cameron_zank is offline
Old October 18th, 2014, 01:27 PM
Dangerbird's Avatar
The rear brake drums are stuck to the brake pads. take off the rear wheels and hit them with a hammer or try to drag the car to get them to break free.
Dangerbird is offline
Old October 18th, 2014, 01:39 PM
m371961's Avatar
Or the emergency brake cable is froze in the brake on position.
m371961 is offline
Old October 18th, 2014, 01:48 PM
Thank you! I will get back out there and try to break them free. Is there a reason why the rear drums did that and not the front drums?Emergency brake?
Old October 18th, 2014, 01:58 PM
Dangerbird's Avatar
Well if they are they are drums all around they all could be stuck, its just from rust and sitting too long, i just broke free a set last week. They can be a bear!
Old October 18th, 2014, 02:06 PM
67 heavy metal
delmontcrusier's Avatar
Gotta love those rear drums when they stick. I ran into that many times and know I have at least one car I will have to deal with that when I get to working on it. I figured you had a clunking or something like that. My 67 had worn parts replaced in the rear diff from noise and clunking before I bought it and got the old parts in a bag. Hope that is all it is keep us updated.
delmontcrusier is offline
Old October 22nd, 2014, 09:08 PM
55 2nd series's Avatar
Don't know your location, but how about a 1968 98 convertible to go alongside your new car? I'm getting ready to list it for sale here and possibly over at evil-bay. It is complete with original motor and drive train.
At this point, it's restorable but will need some TLC. Some people say that stands for Time & Lotsa Cash, but there were only 3,942 '68 98 convertibles made out of 662,894 total production Oldsmobiles made that year. I was also told that the '68 98s were the lowest production post-war Olds convertible made.
Just thought I'd throw it out there to you before I posted it to the masses.
55 2nd series is offline
Old October 23rd, 2014, 02:58 AM
Another possibility is that the rear brake hose is swollen inside, allowing brake fluid pressure to go into the wheels, but not come back out.
If so, and if backing off the adjusters all the way and banging and using penetrating oil doesn't work, the solution is to cut the hose, releasing the pressure.
MDchanic is offline
350TurBRO
September 12th, 2014 11:52 AM
keridan1
June 25th, 2014 01:23 AM
Townie
February 2nd, 2014 04:04 PM
cuttysupreme72
19
August 18th, 2012 08:48 PM
kenny
October 23rd, 2010 06:29 AM
Quick Reply: Issues With 68/98 rear end
