1967 Olds 98 Turn Signal Switch Repair ??
Old October 9th, 2018, 07:04 AM
jday1961's Avatar
I have a 1967 Olds 98 Convertible, Turn Signal Kit needed to be installed on Tilt and Telescoping Column.
Deoes the entire Steering Column have to come out ??
Thanks in advance. Joe
jday1961 is offline
Old October 9th, 2018, 07:16 AM
jday1961's Avatar
I have a 1967 Olds 98 Convertible with Tilt and Telescoping Steering Wheel.
Will I have ot remove the sterring column to put in a Turn Signal Repair Kit ??
Thanks in advance.
jday1961 is offline
Old October 12th, 2018, 06:00 PM
Oh no, not again...
Nailheadcanuck's Avatar
Location: Sherwood Park, Alberta, in the Great White North
It all depends what's going wrong. The switch itself may be separate from the column. However, the return cam and that may be in the column. you'd be best to get a copy of the chassis service manual and have a look. Unfortunately I don't have one for a 67 Olds, only Buick, and that's probably different from Olds.
Either way you're probably going to have to pull the wheel and the horn switch to get at the cancelling cam. The electronics may either be there (they were in the post 69 models, not sure about the earlier ones) or they're located on a separate part of the column under the dash, controlled by a rod from the signal switch. You probably don't have to remove the column.
Nailheadcanuck is offline
Old October 13th, 2018, 11:56 AM
Phantom Phixer
Charlie Jones's Avatar
From the 1967 Oldsmobile shop manual ;
The steering column will have to be removed on floor shift models.
There are several special tools involved in this job . If you don't have them , turn the job over to someone that does .
It's very easy to f*** one of these up . Ask me how I know .
Here's a few pages from the manual ;
Charlie Jones is online now
Old October 15th, 2018, 11:51 AM
D. Yaros's Avatar
I doubt there were very many, if any, "floor shift models" of the 1967 98 full-size Oldsmobile?
D. Yaros is offline
Philfinley
August 17th, 2019 07:52 PM
reoreo55
May 23rd, 2019 04:28 PM
bobbyshaw
October 22nd, 2016 06:13 AM
Bud262
September 28th, 2016 06:39 PM
justinj
February 2nd, 2014 05:32 PM
Quick Reply: 1967 Olds 98 Turn Signal Switch Repair ??
