steering wheel for '68 Ninety Eight
Hi all - just got my 68 Olds 98 LS last week. I'm trying to get her on the road and need a steering wheel that has the horn built into the perimeter of the wheel. Or maybe someone knows of some other steering wheel that will fit. The car has tilt and telescope option. Suggestions greatly appreciated!!
Those Rim-Blo wheels can be repaired. Someone posted a link to video of doing one on a Cougar wheel a couple weeks back.
Your other option is to find a 71-later regular steering wheel. I think about all the T&T wheels from 67-76 are interchangeable, but 67-70 are likely to have a rim-blow.
I have the same dilema on my 68, my horn still works but the wheel is cracked. I bought a used 67 tilt/tele wheel, which has the horn in the hub/center and you can transfer your wheel pad and emblem to look pretty correct. It does not have rim blow or the woodgrain perimeter applique, otherwise is the same wheel. A good temporary fix while you save up some $$$ for the original wheel's restoration. I have not made the switch yet, and plan to have the original restored too, let us know who you use and the results. Hope this helps, Dave
Thanks Dave for the alternative - I am calling around for 68 T&T wheel and will expand my search. I got an estimate from "Dest in Show Steering Wheel Restorations" to restore to new with new horn switch - $750!
I takes them 6-8 weeks as well. I'll still probably do it once I find second wheel. Your Olds looks amazing! Looks like it has every option and then some dealer installed as well. I have been looking for a radio for mine and the am/fm with woderbar can be had for $500. Oh well one thing at time..
- Brian
- Brian
Brian - there is a 67 Toronado wheel and column on ebay now. My car is loaded, I found it for sale on this site, and a few months later the original owner contacted me, he still had the window sticker! He told me he wanted the Olds to be as loaded as a DeVille. It is a great car, everything works, but the car was pretty tired, so my 2 sons and I embarked on a resto. It is apart right now, in the painting process, engine comes out soon.
I also found my 98 on ebay. Its a 4 door LS with std ac. The car is a bit rough and will be a project car. My first ever car was a 68 98 town sedan that I totalled on a winter day back in 1978. Its great to have it back in my garage (well - barn). Up here in new england ther are none of these cars left in salvage yards so its going to be tough (and costly) to get parts I know.
Your so lucky to have such a incredible interior on the 2 door.
I'll check ebay for the steering wheel you spotted. Thanks again - Brian
Dave - I'll take some this weekend and post them up. So far the only work I have done is to install the aftermarket "Rocket 455' air cleaner decal I bought from Drdecal. Looks perfect. The car came with a pair of 68 98 tailight assemblies in the trunk if someone needs them. How many 68 98 CO members are out there? - Brian
EightballZ
May 13th, 2013 04:56 AM
Wil Lopez
Ninety-Eight
August 29th, 2010 09:41 AM
