stalling issues on my 85 olds 98 regency broughm
Old August 12th, 2012 | 03:14 PM
smoknrhonda's Avatar
Has a 3.8L engine. no codes come up. no check engine light. Help! I bought this car 2 weeks ago. it has only 45,000 original miles on it. it might as well have 145,000 miles. when i test drove it ( 2 diff. occasions) it an fine. no stalling no hesitation had good pick up. then the second time i test drove it it stalled twice as i slowed to a stop. started right back up and that was that. well i bought the car drove it home no issue. later i went to the store and it started sputtering and bucking like it wasn;t getting gas, and was trying to stall. i put the gas peddale to the floor and it finallly caught and had power. about 2-3 min it did it again. when i stopped it stalled. started right back up. now this has been going on since and its worse.i basicaly have to shift it to neutral when i'm coming to a stop and hope when i put it in gear to go it doesnt stall. been taking 2-3 tries b4 it starts, I drove it to a mechanic friends after it sat for 2 days didnt go any faster than 40 mph and it never tried to stalll or have the sputtering jerking hesitation. I've replaced the plugs wires rotor and cap, air filter fuel filter fuel pump(the previous owner said they put new one it well it quit working the other might when my car was being looked at.) checked for vaccum leaks, checked the fuel pressure. nothings worked, it still does same thing. any suggestions what the problem is? Does anyone know where i can get schematics showing the locations of the selonoids.??? Plz help im desperate. i need my car for work. .
also i notice there is a lot of pressure released from the gas cap. I mean a lot. more than i. have ever experienced when getting gas. is this normal. lot of pressure when they replaced fuel filter. gas kept coming out even with the fuse to the pump removed.
Last edited by smoknrhonda; August 12th, 2012 at 03:29 PM. Reason: forgot to list motor size
Old August 14th, 2012 | 12:26 PM
Red Delta's Avatar
Registered Abuser
Sounds like the torque converter lockup. I disconnected mine on my 88 Cutlass, no more trans lockup, but no more annoying stall out. I didn't keep the car long enough to repair it, so I don't know the procedure.
The plug is on the left side of the trans.
llj537
Ninety-Eight
April 16th, 2008 08:42 PM
marcar1993
April 21st, 2007 08:48 PM
Dads98Broughm
Ninety-Eight
October 25th, 2006 01:31 PM
Dads98Broughm
October 9th, 2006 09:07 PM
<Dennis Oliver>
March 14th, 2004 09:58 AM
