Speed control throttle sensor
Old Aug 1, 2014 | 12:21 PM
STELLA67's Avatar
I am in need of some info on the what I am calling the spend control sensor. Mine broke and now my throttle and pedal will not work. Does anyone know what the part# or where I can get this?
Old Aug 2, 2014 | 05:54 AM
STELLA67's Avatar
Ok looks like I'm looking for a switch pitch torque converter switch. I have the GM # and Delco below. Anyone know where these might be sitting?
Old Aug 2, 2014 | 05:55 AM
STELLA67's Avatar
Here is the gm#
Old Aug 2, 2014 | 06:07 AM
Octania's Avatar
What are the symptoms that make you think this pat is bad?
I have heard they can get carboned up inside and fail in interesting ways. If you can't find a new or good used one, maybe yours can be opened, fixed, and re-sealed.
Old Aug 2, 2014 | 06:42 AM
STELLA67's Avatar
Look at the first picture it is completely broke off at the bottom making my gas pedal useless .
Old Aug 2, 2014 | 06:44 AM
I don't see anything broken.
Perhaps you should take a clearer picture.
Old Aug 2, 2014 | 06:51 AM
STELLA67's Avatar
I am not where I can take a picture right now and it is on the make of the firewall behind the engine. But if you look at the picture you can see the fresh metal and two bolt holes where the metal casing went all the way around the switch. with out it secure to that bracket it will not properly pull the throttle rod back.
defiant1
Feb 4, 2020 08:53 PM
Joe.S
Oct 26, 2012 02:28 PM
cniguy
Nov 3, 2011 01:45 AM
salisbury99
Jul 5, 2008 05:26 PM
beebee007
Aurora
Aug 17, 2006 06:45 PM
