Should I buy this 67 98 Luxury?
Old Mar 10, 2015 | 11:40 AM
  #81
Professur's Avatar
215/75/14 is the size of the tires on my '91 sonoma.
Old Mar 10, 2015 | 11:43 AM
  #82
mikeamondo's Avatar
From: Northern West by the grace of geography Virginia
Meaning too small for this car, I assume...
Old Mar 10, 2015 | 11:57 AM
  #83
Your original tire size specified for the '67 98 in the SPECS Guide was 8.85-14.
That translates to 245/70R14 or 255/60R14, which are about an inch larger in circumference than a 215/75R14, and turn 755 times per mile versus the 215s' 733.
That's only a 3% difference, so, though those tires will look small, they won't make the engine scream.
Old Mar 10, 2015 | 12:54 PM
  #84
mikeamondo's Avatar
Thanks for doing the math on that, Eric! I'll replace them with the right size pretty soon. Still tracking down the noise issue... did you see I started a new thread for this car... since it's back now the question of whether I should buy it has become whether or not I should have bought it... I tested the fan... moves about 1 blade when you swat it.
Old Mar 10, 2015 | 01:00 PM
  #85
Is that hot or cold?
With a hot engine, that could be okay. With a cold engine, I would expect it to move more freely.
One way to test would be to remove the fan and clutch and go for a quick drive around the block - if the noise, or part of the noise, is gone, you've got a bad clutch.
Do any others have opinions on this?
Old Mar 10, 2015 | 01:09 PM
  #86
mikeamondo's Avatar
That was cold... I good swat moved it maybe one blade, no more... certainly not a full spin, or even half way around...
Old Mar 10, 2015 | 01:16 PM
  #87
That sounds tight to me. I'm going to bet that's part of your noise problem.
Old Mar 10, 2015 | 01:21 PM
  #88
lshlsh2's Avatar
71 cutlass convertible
Sounds like your problem. Had mine go last summer, was very loud. Good news it is an easy fix, about an hour and if I remember right about $30 for a new one.
Larry
Old Mar 10, 2015 | 05:00 PM
  #89
mikeamondo's Avatar
Is this what I need to replace it? http://shop.advanceautoparts.com/p/c...searchTerm=fan#
Old Mar 10, 2015 | 05:37 PM
  #90
That one should do it.
Originally, GM made a very wide variety of slightly different clutches to suit each configuration very well, but the aftermarket has consolidated them into a relative few.
The one you listed is the same as a Hayden 2747, but there are a few other possibilities, as well.
This question comes up around here every so often. Two threads I found are here and here.
442much
Apr 29, 2011 11:40 AM
FiveWoods
May 20, 2010 09:17 PM
Erinyes
Feb 22, 2010 06:26 PM
Oldmobile
Feb 10, 2009 08:06 AM
shaks 442 clone
Dec 19, 2007 01:46 PM
