Pics of trunk 64/98
Old Mar 25, 2014 | 03:07 AM
1Fastolds's Avatar
Pics of trunk 64/98
Can someone point me in the right direction for pictures of what the trunk of my 64/98 is supposed to look like? Mine is in complete disarray and I don't know how the spare or the jack and whatnot are supposed to actually sit in there. I'll post pics of mine, if you are interested in seeing the disaster.
Adam
Old Mar 25, 2014 | 10:33 AM
rocketraider's Avatar
Oldsdruid
Spare tire goes on the shelf under the package tray- orient it for easy access to the valve stem. There should be a threaded rod and wing nut to the right side of that shelf and a bracket with a "sawtooth" edge. The jack base goes there- thread the rod thru the hole in the base and jam the base against the sawtooth bracket and spare to hold it in place. Flat side of the base faces out.
There's another stud and wing nut on the driver side of the shelf. The jack hook goes there.
At the rear edge of the trunk- shelf between the taillight panel and the trunk well- the jack mast goes there. There's another fixed threaded rod with wing nut back there on the right side. Should also be a small "stepped" bracket with a slot in it. Put the mast between the stud and taillight panel, then clamp the stepped bracket over it and secure with the wing nut.
Old Mar 25, 2014 | 11:03 AM
Don R.'s Avatar
Depending on the tire size you may have a problem getting those 15" wheels into the spare shelf. I have 235-70-15's and they won't fit.
Old Mar 26, 2014 | 03:14 AM
1Fastolds's Avatar
Thanks for the help! You have a way with words- I'm going to try and put it back together. Right now, I don't have a jack in there, and my spare is just laying in the trunk. I think some, if not all of the hardware to hold it down is still there. Although I might have to beg and borrow for the right stuff.
Adam
Bitburger
Mar 17, 2012 04:04 AM
cutlassgal
Sep 20, 2011 04:46 PM
1969w3155
Jun 14, 2011 10:12 PM
Sixgun77
May 31, 2011 08:24 AM
citcapp
Jan 21, 2009 05:17 AM
