Fuel Tank?
Old Aug 23, 2010 | 12:24 PM
66ninetyeightls's Avatar
Land Yacht Captain
Fuel Tank?
So while on my way to the Oldsmobile Club of Canada Nationals last Friday I found out the hard way that my fuel guage no longer works. Then after filling the tank to make absolutly sure I didn't run out I found she is leaking at the seam.
Do they make replacement tanks for these cars or should I just take it off and try to have it repaired?
Old Aug 23, 2010 | 12:25 PM
TripDeuces's Avatar
Isn't Spectre Fuel Tanks in Canada?
Old Aug 23, 2010 | 12:31 PM
Land Yacht Captain
Yeah in their E-catalog it says "part Not Available"
Old Aug 23, 2010 | 12:33 PM
Land Yacht Captain
Any ideas what other years would fit?
Old Aug 23, 2010 | 12:42 PM
TripDeuces's Avatar
Yeah just looked it up myself, sorry. They also say you can call. Maybe they can help
Old Aug 23, 2010 | 01:02 PM
Land Yacht Captain
Just checked the interchange manual in the tech section.
559 393003 Olds '66 98.
Apparently its only applicable to that year & model. DAMIT!!!
Called a gas tank repair place near by. Have used them before with good results. $275CDN to sandblast inside and out. Repair any holes. Install a liner inside and expoxy coat the outside. (3 Year Warranty)
Old Aug 23, 2010 | 05:43 PM
bigoldscruiser's Avatar
2 '66 98's
Called a gas tank repair place near by. Have used them before with good results. $275CDN to sandblast inside and out. Repair any holes. Install a liner inside and expoxy coat the outside. (3 Year Warranty)[/quote]
It is either go that route or have a new stainless steel one custom built for about twice that money. My friend in Milwaukee just took the alternative. That is how I know!
I have had problems several times over the years with leaking around the filler pipe. I repaired it myself by removing the tank, filling it with water and then lowering the water level enough to be able to re-solder the joint. More then one person told me I must be crazy! I'm still here!
Bruce
dfire25
Jun 28, 2016 01:37 PM
bob p
Mar 18, 2015 09:51 AM
pfergy600
Oct 4, 2014 05:29 PM
1carsick
Oct 17, 2012 09:10 AM
Texas442
Jan 30, 2012 05:36 PM
