AC issue 77 regency
AC issue 77 regency
Hey guys I have a problem with my ac coming out of my dash vents in my 98. I experienced it last summer after I got it recharged. It wants to blow out of the floor vents and takes up to 10 to 15 minutes for it to come out of dash vents. I don't know if I have a stuck door or bad vacuum line in there. But this summer I want to get that fixed so I have cold air right when I turn it on. What do you guys think and is this something a shade tree mechanic like myself can tackle?
Sticking doors or actuators due to deteriorating rubber seals
Low vacuum
Leaking vacuum lines or selector switch in the HVAC control head on the dash
Sticking check valve where the vac lines connect to the vac storage ball on the firewall.
So I would want to check the HVAC box first. Is that a pain to get into? A leaky vacuum line would be the easiest. If it has low vacuum then its a problem with the storage ball or a line right? And what if rubber seals are bad around flapper doors? Thanks a lot Joe
Dead Reckon
Jul 14, 2014 02:35 PM
