1970 olds 98 455 rear end posi
Old Sep 15, 2007 | 09:00 AM
troy1's Avatar
I would like to change the rear end from 2.73 gears to 3.42 and add a positrac.
any spec information to start hunting for parts would be appreciated.
troy
Old Sep 15, 2007 | 11:11 PM
88 coupe's Avatar
Junior Member
Check with Brian: thetrickfamily@yahoo.com
He is a well known Olds guy, whose specialty is Olds rear ends.
Norm
Old Sep 18, 2007 | 06:20 AM
Kennybill's Avatar
You will have to go to an after-market housing such as a corporate 12-bolt GM or a Ford 9". After-market gears are non-existant for 1965-1970 Olds. The best u will find, if u r lucky, is a 3:08 posi. I am into the "big" Olds and I have looked for years for better gears, the best I have found is 3:08. I have several 3:08 Posi, most in my cars. Good luck, Ken
Old Feb 8, 2008 | 03:54 PM
rocket9r8's Avatar
hey there, yep kennybill is on target, nobody home in the after market, i did all what kenny said to my 98 convertible except the rear end boy does it scoot! thanks kennybill
Old Feb 12, 2008 | 01:49 PM
Edveen's Avatar
Richmond Gears makes aftermarket Rings and Pins for the O-type posi unit.
http://www.richmondgear.com/01gm.html
They only fit for the #671 (3.08's 3.23's) posi carrier though.
This information is from Brian Trick (as mentioned above). I've mentioned this before. If your going the posi route, I highly recommend for anyone to talk with him. He is awesome.
By the way, Brian can make those richmond gears fit #672, #588, and #673 posi carriers.
monzaz
Dec 17, 2016 07:37 AM
350TurBRO
Sep 12, 2014 11:52 AM
Bob Kelso
Nov 16, 2012 01:21 PM
1970442w30post
Aug 2, 2011 05:07 PM
esisson
Feb 7, 2011 11:34 PM
