1964 Olds 98 brake booster
Old Mar 15, 2017 | 12:20 PM
Jandk's Avatar
Does anybody know what brake booster a 64/98 what fitted with back then??
I am about to get a aftermarket booster setup now, and from what I can measure I have enough space to fit a 8" single or maybe a 9" because of the inner fender. Can any of you other 1964/98 owners support me on this one??
Old Mar 15, 2017 | 12:29 PM
Stock would have been 9". You want to fit the largest you can, or else get a dual diaphragm unit to ensure adequate assist for such a heavy car.
Old Mar 15, 2017 | 12:56 PM
Jandk's Avatar
When looking online which is what I am doing at first, I havent come by any boosters with any measurements so far, but eyeballing using fotos found here and there, I would say I will never get a dual diaphram to fit because of the inner fender..
I have roughly a 4" gab from firewall to inner fender 4" from center of where the booster is fitted to the firewall. I am guessing a dual diaphram is waaayyyy longer from firewall and ourwards.
Honestly, I have never had one in my hands, And have only seen them in other cars, and remember sticking quiet a bit out horisontal.
That said... it is possible to get a universal slimline 9" single that is claimed to be more powerfull than a 7" dual and 8" single. http://www.ebay.com/itm/Universal-9-...item2ed90826ad
I have just removed a 8" single from a possible european car... it did a good just, so I guess it can not get any worse :-)
Old Mar 15, 2017 | 01:07 PM
They can claim whatever they want - math doesn't lie. The booster force is simply diaphragm area times air pressure. The air pressure is the same for both, so area is all that matters. A 7" booster is about 38.5 square inches (ignoring the area of the actuation valve in the center of the diaphragm). An 8" booster is about 50 sq in, or about 30% more power assist. A 9" booster is over 63.5 sq in, or 65% more assist as compared to the 7". A 7" dual diaphragm booster has 77 sq in, which is obviously double the 7" single and 20% more assist than the single 9" booster.
Old Mar 15, 2017 | 01:14 PM
Jandk's Avatar
THAT is correct.....
I better get some measurement on some of those boosters, then it will be much easyer to decide.
Thank you Joe
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
67 Cutlass Freak
May 13, 2014 05:26 PM
59-59-59
Oct 6, 2011 07:46 PM
1971viking
Dec 26, 2010 10:17 AM
59-59-59
Jun 3, 2010 08:34 PM
