1970 442 headlight replcement
Old Sep 10, 2015 | 09:20 AM
bumble-70442's Avatar
Hi I am a nweby and am having a problem removing existing headlights from car. Do I have to remove the bezel and the inner plastic surround to remove the bulb?
Old Sep 10, 2015 | 10:19 AM
If it's the car in your avatar photo, remove the metal bezel, then remove the stainless retaining ring that holds the bulb to the headlight bucket. The plastic surround does not need to be removed. You may have problems with the small phillips head screws that hold the retaining ring, as they often rust to the bucket and the head is easy to strip. Also, be careful not to break the spot-welded tabs off the retaining ring (although replacements are available). Note that the three screws holding the retaining ring are not equally spaced, so be sure to line them up properly when reassembling.
Old Sep 10, 2015 | 11:15 AM
Thanks, you confirmed my beliefs it just seems like very tight quarters
BeenThere
Apr 4, 2015 05:02 AM
oldspackrat
Nov 8, 2014 01:04 PM
69442murph
Feb 2, 2014 06:35 AM
joesw31
Oct 21, 2011 11:23 PM
hdvettes
Dec 30, 2008 09:27 PM
