Hi, I'm Phil from Portland.
Old Mar 23, 2015 | 09:38 AM
surfin_phil's Avatar
I was visiting family in Phoenix, AZ and went out to some garage sales. Found this 1966 Olds Dynamic 88 Convertible and bought it. Met the original owners daughter at the sale, she said her mom got it for her birthday in 1966 in Michigan and then moved to Phoenix shortly after. It has 65000 miles and is completely original including the convertible top cover.
I decided to make an adventure of it and drive it the 1300 miles from Phoenix to Portland. First attempt, blown lower rad hose 20 miles into the trip.
Went back to the inlaws house, replaced the hose, water pump, thermostat etc. Put on some fresh tires (already had new brakes).
Set off again, made it to Vegas where the bypass hose sprung a leak. Went to a great little rad shop and had him throw in a new thicker rad. Pushed on to Reno that night without incident. Got up the next morning and drove 9 hours straight to Portland.
Now the fun begins!
Will need lots of advice starting with exhaust (still has that silly crossover thing) and ignition, would like to get modernized set up like HEI or something.
Old Mar 23, 2015 | 09:43 AM
Welcome to site Phil. Thanks for sharing the story and pictures, she sure is sweet.
Old Mar 23, 2015 | 10:01 AM
Oldsmaniac's Avatar
Awesome find and a true time capsule! HEI no problem and you can upgrade to dual exhaust. The special left side exhaust manifold is reproduced and can be had from Thornton. It will give some xtra HP too.
Old Mar 23, 2015 | 10:05 AM
Rocketowner's Avatar
Welcome Phil,you've already past the first testof owning a classic "Bravery", for trying to take on a 1300 mile trip without completely knowing about your purchase. Just don' t get discouraged and quit before you get it like you want it. Olds was a good choice . Larry
Old Mar 23, 2015 | 11:00 AM
rcorrigan5's Avatar
Randy C.
Welcome to the site, Phil! And another beautiful find that seems to come up here every once in awhile, and she's all for you! Thanks for sharing!
Randy C.
Old Mar 23, 2015 | 11:10 AM
Sweet find! You're braver than I am driving it with rubber parts that old. Hope it had an oil change too. Be wary of the oil you use as most of it nowadays doesn't have enough zinc for the old flat tappet engines. I'd also check those brake hoses, brake hardware is one thing but hoses can look fine even when they're not. Don't ask...they let go when you least expect them to.
How much did you pay for that gem?
Old Mar 23, 2015 | 11:17 AM
It did have all new brakes and lines as well as some front end parts and new front springs. I paid $7k.
What is the recommended oil for this engine?
Old Mar 23, 2015 | 12:08 PM
10W30 with high zinc content. Something like Shell Rotella T or Amzoil Z-Rod would work. So will a lot of others. Just google 'high zinc motor oil' and you'll find a lot of product.
I wouldn't use the stuff for new cars though as they all use roller rockers and very little zinc. You want oil with at least 1300ppm of zinc. IF you decide to buy regular oil, you can add ZDDP additive to boost the protection level if you want; that's another option but it's your call.
7K sounds a bit high, but I'm inclined to think you did fine to get a survivor car like that. You know the old saying - When the top goes down the price goes up!
Old Mar 23, 2015 | 12:52 PM
Yep, thought it was a little high to but went for it due to the fact that other than the front seat material, the interior is perfect. There is absolutely no missing trim anywhere on the car. I like cars that are all original like this and unfu$#ed with
Old Mar 23, 2015 | 01:05 PM
I probably would have pulled the trigger too. These don't come up all that often in fantastic survivor shape.
You probably can find a good upholstery shop that can do a repair on that seat, unless you want to just leave as is for the sake of originality. Dad had those plastic seat covers put onto our 67 when it was newer to save the cloth inserts on the seats. It was good for that but really uncomfortable to sit on especially in the heat. In the winter it was a bee atch too.
FYI, I really like the body color - Lucerne Mist? Paint code D? It will be on your cowl tag (right side of the firewall beside the brake booster) Looks similar to this one for a 1966 Cutlass Supreme Coupe
[IMG][/IMG]
Old Mar 23, 2015 | 01:06 PM
Oldsmaniac's Avatar
Well you could not restore a car like this for under 7 G's so I think you did ok, I like it! Not a bargain but fair.
Old Mar 23, 2015 | 01:13 PM
tru-blue 442's Avatar
Old School Olds
Welcome, I like it. Probably will be the only one in town. Square deal, enjoy.
Old Mar 23, 2015 | 02:27 PM
jcdynamic88's Avatar
congrats on the purchase .i think you did just fine on the price.i sold one in similar condition last fall for $8200.only problem with your car is when you hit the road with the top down you won't want to come back.i run the rotella 15-40 in my 425.
Old Mar 23, 2015 | 03:34 PM
Magna86's Avatar
Sweet looking ride! I bet the ride was sweet once you got back on the road.
Old Mar 23, 2015 | 04:54 PM
Beautiful car. Welcome to ClassicOlds!
Originally Posted by surfin_phil
I... would like to get modernized set up like HEI or something.
Why?
Old Mar 24, 2015 | 04:31 AM
35tac's Avatar
Phil, nice car and a great find. My 66 Cutlass was a Lucerne Mist. Love that color. Any chance you can post a pic of the cowl plate with the codes on your car?
Congratulations
Wayne
Old Mar 24, 2015 | 12:02 PM
Originally Posted by MDchanic
Why?
X2 on this. I seriously doubt that you're going to be driving this a ton, and a properly maintained stock ignition and distributor will work every bit as good. This path has been discussed waaay to many times in the past.
I'm also not sure why you'd do it because maybe I read into your post that you were a fan of keeping things original?
Changing to a dual exhaust is your call. Be aware it will increase the noise inside a fair bit although it will allow the engine to flow a bit better. Chances are this car is equipped with a 330 CID and Jetaway trans? I'd keep it stock for exhaust as there never was a true dual exhaust for the SBO IIRC. They just used a block off plate and called it the N10 option. Only the BBO got a true dual system. You could go the header route but it's also a bit of a PITA to install, plus it won't look stock either. Just my 2¢....
Old Mar 24, 2015 | 12:04 PM
Old School Olds
Allan, I thought these boats were equipped 425, no?
Old Mar 24, 2015 | 12:06 PM
Oldsmaniac's Avatar
That is correct the 330 only in the B body Jetstar88.
Old Mar 24, 2015 | 12:09 PM
Oldsmaniac's Avatar
The key to quiet dual exhaust on these cars is to use resonators with the stock mufflers and stock pipe sizes. But yes I agree it will get just a tad louder but never annoying or harsh with resonators.
Old Mar 24, 2015 | 12:25 PM
Yep, think I will stick with stock ignition. I ordered a set of manifolds from Thornton (he gave me a nice deal). Will go with standard pipes, mufflers etc to keep it to a nice rumble.
Yes it has a 425 in it with a 2BBL Rochester, freshly rebuilt.
Old Mar 24, 2015 | 12:37 PM
Sorry guys, I was looking at the wrong application. Yup, 425 so it could easily have a dual stock application right? X and W exhaust manifolds?
Just wondering here about whether resonators are the best way to go. Didn't these cars have chambered exhausts from the factory?
Old Mar 24, 2015 | 12:54 PM
Just bear in mind that on a 425, any performance gains with dual exhaust will be pretty much negated by keeping the 2-Jet.
There's nothing wrong with the 2-Jet, and on a smaller engine, changing to a 4bbl will have a very minimal effect on performance, but on a big engine, a 4bbl will improve performance, especially when mated with dual exhausts, but the exhausts alone won't make much difference with the smaller carb - It's fine to let the air get out easier, but doesn't matter if the air can't get in in the first place. ')
Old Mar 24, 2015 | 12:59 PM
Oldsmaniac's Avatar
The left manifold for duals is S the right side is the same for duals or single, I dont know the letter.
On the dual exhaust cars there were 2 resonators and a single resonator on single exhaust cars. No chambered pipes on the B bodies at least in 65 and 66...
Old Mar 24, 2015 | 01:05 PM
Oldsmaniac's Avatar
Manifolds? You only needed to order the left side or S manifold unless yours were junk.
Old Mar 24, 2015 | 01:09 PM
Ah, yes, the old "nice deal" on the unnecessary parts...
Old Mar 24, 2015 | 03:15 PM
Correct! Unnecessary but no crossover thingy to block off and shiny!
Old Mar 24, 2015 | 03:48 PM
W - but I cheated and looked it up.
Troy will sell just the single manifold you need for 229.00. This is the only one you needed. Your old RS one could easily be removed and freshened up to match if you wanted them both shiny.
Please don't say he sold you the pair for 350.00?? Those will cost a fortune to ship with 2x the weight. They only look new and shiny for a little bit till they are used a few times.
Old Mar 24, 2015 | 04:13 PM
Nope not $350, shipping will be 30 odd dollars. Promised him I wouldn't tell anybody what I paid
Old Mar 24, 2015 | 04:15 PM
Wow, you got a deal on the shipping. Doesn't really matter what the deal was as long as you're happy. BTW those pics are the ones from his ePay website.
Old Mar 24, 2015 | 04:53 PM
  #31
Shiny is good.
Sounds like a great deal.
Old Mar 24, 2015 | 05:02 PM
  #32
manifold
you can buy the S manifold from amazon motor co for $149+ when available, currently 1 left.
Old Mar 24, 2015 | 06:09 PM
  #33
Shiny is good.
Shiny cars go faster
Old Mar 25, 2015 | 06:22 AM
  #34
Cowl Tag for the car.
How do you figure out the color?
Old Mar 25, 2015 | 06:39 AM
  #35
Color is just to the left of 'PAINT'.
D is Lucerne Mist lower body color. A is convertible top color - white.
Old Mar 25, 2015 | 06:45 AM
  #36
You look at the PAINT code, in this case D-1, and then look up the meaning of the number in your model year.
In your case, you have a convertible, so the Paint code contains a letter, for the body color, and a number, for the top color.
"1" is the GM code for a White convertible or vinyl top.
For the rest, if you Google "1966 Oldsmobile Cowl Tag Decoder," you will see this page as your first hit.
It should answer most of your questions.
jcdynamic88
Mar 1, 2014 11:30 AM
dc2x4drvr
Jan 4, 2014 12:31 PM
leepear
Oct 5, 2011 08:03 AM
Brizio
Mar 10, 2009 02:44 AM
IDAS 69
Mar 3, 2009 04:08 PM
