Hi gearheads.
Old Jul 16, 2014 | 09:14 PM
gordo's Avatar
Talking Hi gearheads.
Hi all, I'm new to the forum but I'm usually a serial lurker. I live in Southern Indiana and have just made it official by starting my own auto repair shop. I restore all types of vehicles as well.
Most of the time I can figure things out for myself but this time I need some help. I own a red '67 C/S convertible. All original, numbers matching car. 330 4B w/ Super Turbine 300 w/ switch pitch convertor. I've replaced all 4 shocks and the rear coils so far. I've bought the front coils but I can't seem to find a purveyor that stocks the upper front coil isolators. Just don't know that specifics of the original equipment. Would anyone have any links to where I can buy a couple? The ones that are supposed to be on the car are long gone.
Old Jul 17, 2014 | 05:09 AM
Olds Dad's Avatar
Collector of Stray 55's
Welcome...from a guy who had "GORDO" on his license plate all through high school!
Old Jul 17, 2014 | 06:07 AM
Welcome to the site and congrats on the business endeavor. The 67 does not use spring isolators in the front, rear only. Post some pictures of the car when you get a chance.
Old Jul 17, 2014 | 06:23 AM
Welcome aboard
Old Jul 17, 2014 | 09:55 AM
Welcome. As noted, they were "long gone" when the car was new. Be aware that the top of the front springs must fit over a locating feature inside the frame rail. This is a blind installation and if the spring is not located properly, it will cause the front of the car to sit about an inch higher than normal. An internal spring compressor makes this a lot easier. Also, if you loosen the control arm bolts to install the springs (or to replace the bushings - hint, hint), be sure to torque the bolts with the weight of the car on the springs and at ride height.
Old Jul 17, 2014 | 10:50 AM
citcapp's Avatar
Welcome to CO from the left coast
Waiting for the pictures........................still waiting.....................
Old Jul 17, 2014 | 06:56 PM
gordo's Avatar
Old Jul 17, 2014 | 06:59 PM
gordo's Avatar
Here's some pics of other projects in varying stages or resto/repair.
The 2 pics above are of a '67 RS Camaro that will look like this when I'm done.
Old Jul 17, 2014 | 07:02 PM
gordo's Avatar
The Bonnie was my grandfather's. It has more sentimental value than anything. 36,000+/- original miles. It's got a 2B 400 in it.
Old Jul 17, 2014 | 07:08 PM
Nice rigs, the Cutlass looks really solid.
Old Jul 17, 2014 | 07:32 PM
oldsman72's Avatar
Welcome to the site, gordo!
The Cutlass does look very nice...but I'm diggin' that silver Camaro. '71 RS split bumper? I can't make out what the badge on the hood says. L'il help!
Old Jul 17, 2014 | 08:02 PM
Gary M's Avatar
I had a few Trans Am's but the cutlass is my focal point. That looks very good. Hope it will be finessed too proper condition. Welcome to the site.
Old Jul 17, 2014 | 08:07 PM
gordo's Avatar
Thanks for looking and the compliments. The Camaro is actually a '70 but some call it a 70 1/2 due to GM having line tooling issues and started producing the car halfway through the model year production run. The badge says '350' on the hood. It's an aftermarket fiberglass, had to use it because of the tall intake. It's got a 450 +/-hp mouse in there. Bunch of goodies but no nitrous. It runs good. Roller top end, Dart aluminum heads, TH400 with a manual valve body and a 12 bolt/ Strange axles, 3.83 gears with a Detroit locker. It's pretty old school but it's fun to hit the track running 116 octane or so. It pulls the front end up off the pavement if I want but I don't beat it up too much.
Here's a video of the Cutlass running.
nukesec1
Nov 30, 2013 09:02 PM
1BAD71455
Aug 13, 2013 09:41 AM
