1949 Olds 98 Building streetrod, have questions!
Been awhile since I was on here, finally got my Fatman frame installed now trying to find a replacement gas tank as mind is leaking. I'd like one that has the pump inside as I'm installing a LS1 engine. Also wondering who offers a replacement instrument cluster other than Classic gauges. Any help would be greatly appreciated.
Did you try Tanks Inc. for gas tank? http://www.tanksinc.com/ They also have setups for pumps inside the tank. In case they don't have an exact copy have your tank dimensions including which side filler neck is on and location of filler neck i.e. does it go in the side of the tank toward the front, middle or rear. I got a new tank for my 47 Olds that they listed for a Buick but it fit just fine.
