Newbie from Modesto, CA
Hi My name is Scott and I recently purchased a 1962 F-85 Cutlass with no engine and transmission. I found this site and have since found out there is not much out there as for interior parts for these things. Every catalog I look at has hardly any 1961-1963 cutlass parts and a ton of 1964-on up. I am wondering is there any hidden sites online that may have some seat upolstery or is the only option to have custom made stuff.
Again I am new and have searched but not much has poped up.
Thanks,
Scott
Thanks,
Scott
I think your best bet for interior would be to get an upholstrey shop to try to copy the original stuff. I know there are a few in the Bay Area that could do it. As far as the valley none I could recommend as I just moved to Ceres two years ago.
Thanks everyone for the responses. I was looking for some factory style seat covers pre made and some foam. My wife's father does do upholstery in modesto I just didn't want to have him do it and not charge me for the labor. He is retired and does it from home but is getting up in the years and does not do many cars anymore.
Thanks I will just have to have the interior redone. That's not a issue. I just got back from looking for the original engine and transmission at the previous owners house and came up empty handed. Looks like I am either putting a stick in it or cutting the floor up. Is it really a crime to put a chevy engine in these cars? They just seem easier to get your hands on.
Scott
Scott
Yes.
Seriously, you're building this car because it ISN'T a 69 Camaro, so you want to put another belly-button Chubby motor in it? Yeah, it's been done, but...
ZZZZZZZZZZ
If you want to dare to be different, consider a Rover 4.6 liter. The Rover is externally identical to the 215 (including motor mounts and bellhousing bolt pattern). You can run the EFI or any intake that fits a 215 (like the new E-brock intake). F-85 exhaust manifolds bolt up. Use a T5 (D&D sells the bellhousings). That's what I'm doing on my 62.
Keep in mind that these cars only weigh about 2600 lbs. It's pretty easy to get 250-300 HP out of a Rover 4.6 (they have cross-bolted mains) and that gives you the same power-to-weight as a W-30.
ZZZZZZZZZZ
usertroy
Dec 13, 2012 08:19 PM
