Olds rule
Old Feb 22, 2013 | 03:30 PM
71 W30's Avatar
Olds rule
I'm a new member I own a1971 w30 matching numbers 4sp car. It is currently blue with white stripes and guts. I have owned this car for the last 16 years. It is built to go no power brakes or steering. I wouldn't have one any other way.
Old Feb 22, 2013 | 03:52 PM
tru-blue 442's Avatar
Old School Olds
Welcome to CO.
Post some pics, we would love to see it.
Old Feb 22, 2013 | 04:18 PM
citcapp's Avatar
Welcome to CO
X2 on the pictures. Is it stock or built up. A little more background please
Old Feb 22, 2013 | 04:30 PM
Welcome aboard!
71 W30's are hot. Same as ^^^^ please post pics. Sounds like a great car. The lack of PB is consistent with a 70 - 72 W30's with the performance cam. Didn't allow enough vacuum for PB.
Old Feb 22, 2013 | 06:27 PM
71 W30's Avatar
I will get some pics up she is stock. When I got her she had a big carb and intake set up on it. Ran it for a summer like that then put the original equipment that came with the car back on. The carb is correct but the breather is year one reproduction the correct olds intake was with the car as well.
Old Feb 22, 2013 | 06:34 PM
Including the H heads?
Old Feb 22, 2013 | 06:37 PM
71 W30's Avatar
I wish mine has K s on it
Old Feb 22, 2013 | 06:47 PM
Really? You mean KA heads? Those were produced for 73-76 455's. All 71 442 W30's got the H heads. Sorry to hear that yours aren't still on there. PO prolly kept them and sold them - they're worth a small fortune. Intake should be aluminum - Does it have OLDS 455 or OLDSMOBILE 455 cast onto it? 71's only have OLDS 455
Old Feb 22, 2013 | 07:00 PM
71 W30's Avatar
There just marked K my books show them as a factory replacement on 71 W30s
Old Feb 22, 2013 | 07:26 PM
71 W30's Avatar
my intake is the correct one. you can tell my car was torn down once and put back together some one thought they should put a bunch of go fast parts on there. I still have to find the correct bell housing as mine is a racing scatter shield type.
Old Feb 22, 2013 | 09:19 PM
Now you've got my curiosity going. Do you mind sharing the name of the book?
Old Feb 23, 2013 | 09:45 AM
71 W30's Avatar
I will look it up been a while since I've gone through my olds stuff
Old Feb 23, 2013 | 09:49 AM
71 W30's Avatar
I lookedthrough some books I had quick this morning but no identification at all in them I will remember which book it was and post it
Old Feb 23, 2013 | 05:33 PM
71 W30's Avatar
If you google olds FAQ heads it will show you all kinds of identificationCodes for heads including the K head is a replacement for W30 4sp motors
Old Feb 23, 2013 | 05:45 PM
First of all, the FAQ is full of a lot of errors, so don't believe everything you read there. Second, the factory regularly superceded parts when original parts were no longer available for replacement. The K heads are perfect examples. These are NOT the same as the H heads used on 71 W-30s. What happened is that by the mid-1970s, the only head castings available in the Olds Replacement Parts network were J and K heads. The factory parts book lists J heads as the replacement head for every low-perf application, and the K heads for every high-perf application, mainly W-30s and H/Os. Because of this, NHRA will accept K heads as a replacement for ANY factory W-30 head in pure stock classes. That doesn't mean that the K heads are the same as D, F, or H heads, just that they provide no performance advantage on an otherwise correct stock motor.
In any case, the K heads were NOT factory installed on 71 W-30s (or any W-30) and thus cannot be "numbers matching".
Old Feb 23, 2013 | 05:55 PM
Rocket331's Avatar
Well, now that Allan and Joe have sufficiently rained on your parade, I'll just say "welcome, aboard!" Don't be discouraged. I've come to realize there are a few folks out there that are a lot wiser about Oldsmobiles than I am. You're bound to learn a few things, too!
Old Feb 23, 2013 | 06:14 PM
m455sx's Avatar
Olds Nut
My SX has the Ka heads and they work very well. Please post pix of your car.
Old Feb 23, 2013 | 06:29 PM
Originally Posted by m455sx
My SX has the Ka heads...
Which are not original for a '70 either - should be D's for an SX, if I'm not mistaken.
Old Feb 23, 2013 | 07:14 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome to CO! Definitely post some pics when you can.
Old Feb 23, 2013 | 07:21 PM
I for 1 never care whats on someones car, however like the rest, welcome and yes post some pic's. I'm just an old car junky.
Old Feb 24, 2013 | 02:40 PM
I'm afraid you are, Eric. E heads for all 1970 455s except W-30. D heads were 1968-69 W-30 and H/O.
Old Feb 24, 2013 | 03:58 PM
Whoops - got it backwards - "D" is the W-30, and E is the regular '70, then F is the Hi-Po after '70 and G is the regular '71 / '72, etc.
What Mustangs ?
Mar 21, 2011 04:40 AM
jag1886
Mar 12, 2011 05:14 AM
derek nesdoly
Oct 22, 2009 10:46 PM
