Excessive Oil Leak Due To Wrong Threaded Plug.
I'm a newsbie and want to share my current dilemma with the second restoration project on my '54 Olds, 98 Holiday Hardtop, 324 ci. Click on links below to see a few pictures of restoration or see thumbnail pics at end of post.
To All: After changing rear main seal twice...still leaked excessively..have retraced leak more thouroughly and found that lhe leak may be from what appears to be an incorrect 'threaded plug'. Unfortunately this required dropping tranny, removing oil pan, pump, flywheel cover, housing etc. to expose rear of engine and the end of crankshaft and metal panel bolted on the rear of engine block, click on link below to see picture when engine block was first brought home from machine shop or see thumbnail pic at end of post.
The excessive oil was around the plug and looked like it was leaking from there.. the plug was removed and one can see that it did not match the threaded block hole. With engine on an upright position, the plug is located on the right sie of the block. When plate bolts and plate is removed, there is a soft freeze plug on the left and a 'threaded plug' on the right. The bolt size is 7/8" and the thread number is 14, with what appears to be straight type threads rather than sloted. Don't know at this time whether the plug has a weep hole from top to bottom or just at the bottom or none at all. Again, since the one we removed appears to be the wrong plug, both in length and in type of thread, which may be why it's leaking through the threads.
Anyone familiar with such a 'threaded plug' in mid year cars or later year cars...what is its function and where does that hole channel go to...? Anyone that has or knows where I can locate such a 'threaded plug', or anyone with an old '54 Olds engine that is willing to part out...let me know? Anxious to get this Olds on the road and cruise....!
DSCN0305.JPG (161.4 KB) To All: After changing rear main seal twice...still leaked excessively..have retraced leak more thouroughly and found that lhe leak may be from what appears to be an incorrect 'threaded plug'. Unfortunately this required dropping tranny, removing oil pan, pump, flywheel cover, housing etc. to expose rear of engine and the end of crankshaft and metal panel bolted on the rear of engine block, click on link below to see picture when engine block was first brought home from machine shop or see thumbnail pic at end of post.
DSCN0154.JPG (144.4 KB) The excessive oil was around the plug and looked like it was leaking from there.. the plug was removed and one can see that it did not match the threaded block hole. With engine on an upright position, the plug is located on the right sie of the block. When plate bolts and plate is removed, there is a soft freeze plug on the left and a 'threaded plug' on the right. The bolt size is 7/8" and the thread number is 14, with what appears to be straight type threads rather than sloted. Don't know at this time whether the plug has a weep hole from top to bottom or just at the bottom or none at all. Again, since the one we removed appears to be the wrong plug, both in length and in type of thread, which may be why it's leaking through the threads.
ds00469
Jan 25, 2014 05:12 PM
