71 Cutlass Supreme Wide Moulding Clips
Hi All. Name here is Joe and am a long-time owner of a 1971 Cutlass Supreme Convertible. Done alot of work on it over the years, but am stumped on where to get the clips for the wide body molding, Its about 3 inches wide I think and the clip pushes in ( no bolt) and looks like a Lazy "S" with a tail connected to one of the "S" arms that is springy and holds the molding in place.
Anyone have a source for these ?
Thanks in advance
Joe (JVCCutlass)
Thanks in advance
Joe (JVCCutlass)
Just did this a few weeks ago. Try UFO fastners look online. I used to get clips for a parts store, supplier was J&T, but could not locate J&T products..I used the bolt on type, this time...but have used the type you are refering to...Seems it is getting harder to find the old time clips try your auto paint store..
Thanks in advance
Joe (JVCCutlass)
Thanks in advance
Joe (JVCCutlass)
If so, there is a vendor on eBay named altha1 who sells a variety of clips and screws for trim. The clip in this pic sells for $11.99 each
and is for 2 inch trim. The eBay item number is 310319685410.
Au-Ve-Co makes nearly all of these clips. Check at your local auto body supply store. They should have an Au-Ve-Co catalog and can order the clips if they are in the catalog. Should be a LOT less than $12/clip.
a picture of the clip I am looking for is attached...it is 3 1/2 inches from tip to tip. Hope someone can point me in the right direction, Au-ve-co has oje that is similar but it is only 1 inch long.
Joe
Joe
