Sending unit mounting
Old Aug 16, 2010 | 07:06 AM
Petercat's Avatar
Question Sending unit mounting
Does anyone know where I can find an aftermarket thermostat housing that is tapped for a coolant temperature sending unit? I had one on a 1969 Dodge 318 once, but I can't locate one for my 1987 Oldsmobile 307. I want to keep the light. Or is there somewhere else on the block that I can mount one? The engine is stock and complete.
I just don't care much for the in-hose mounts.
1987 Cadillac Fleetwood Hearse
Old Aug 16, 2010 | 09:05 AM
I'm afraid I've never seen a t-stat housing like that for an Olds. I assume you have the stock CCC system on your 307, so you're using all the mounting locations in the intake with factory senders and sensors. The best you could do is use one of the fittings that goes in the upper radiator hose and provides a bung for mounting the sending unit.
http://www.4wd.com/productdetails.as...9&partID=59777
http://prosportgauges.com/water-temp...e-adaptor.aspx
http://www.steigerperformance.com/products/sp40001.html
Old Aug 16, 2010 | 09:11 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO.
Old Aug 16, 2010 | 09:20 AM
Petercat's Avatar
Thanks, Joe
Y'know, that Steiger doesn't look half bad... And the price is attractive as well. I'll go for it.
And thanks, Oldsguy, for the welcome.
Old Aug 17, 2010 | 05:53 AM
Welcome
Welcome aboard
Joe will set ya straight
Old Aug 17, 2010 | 06:42 AM
Aron Nance's Avatar
Welcome to CO! And, yes, Joe's the best and will shoot you in the right direction every time.
TheRuss
Sep 30, 2025 05:33 AM
dynamic88
Jul 12, 2009 08:15 AM
Pfiffle
Feb 21, 2008 06:43 PM
boese1978
Jan 22, 2008 11:56 AM
