'61 Super 88 Fuel/Vacuum Pump
Hi all,
I'm new to this site, and I'm really excited that there's a place I can go to talk about these great classic cars.
I have a 1961 Super 88 (base version) with a 394 and a 4-barrel carb. My dad gave it to me when I was 16 and I've been working on it ever since (I'm 22 now). I've got it running enough to insure and drive a few times. I was extremely lucky that my dad had access to another Super 88 when he first got ahold of the car sometime in the early 90s and stripped it of pretty much every spare part so I had two of everything!
My biggest problem is the mechanical fuel pump, which doubles as a vacuum generator for some of the dash controls (like heater vents) and whatnot. I don't have a spare, and the one I have leaks oil like a sieve because the rubber pieces inside are eaten completely through in some places.
I can order a fuel pump to replace it, but it doesn't have the vacuum generator. Is there anything I can do to get vacuum back?
Thanks in advance!
-Logan
Thanks in advance!
-Logan
Logan,
A nice car to bring back to life. I do not quite understand why a fuel pump would be leaking oil, under any circumstances. That said, I see fuel pump rebuild kits on ebay all the time. They should be readily available there, and other places on line.
You will find that there are not that many parts to a mechanical fuel pump. It is certainly a doable job. Go for it!
Logan,
I was a bit intimidated to rebuild the fuel pump but I guess it isnt as hard as I thought
Logan, if you don't have one you need a 1961 Olds Chassis Service Manual. These fuel pumps are rebuildable and the manual goes thru it step by step. You can find one on ebay and it is well worth the money you'll spend for it.
As Dave says, fuel pump rebuild kits are available. Get one that the materials are made to handle modern fuels. An old stock pump diaphram will disintegrate almost as soon as ethanol gas hits it, as I proved to myself on a 64 Starfire a few years ago.
As an alternative if you can't find or rebuild the correct pump, you can find a vacuum reducing valve that will drop the vacuum signal down to about 7" Hg and tap into a manifold vacuum source.
Here's a trick on rebuilding those pumps. Find yourself a pane of flat glass, put some 120-180 grit or so sandpaper on it, and use it to true the mounting flanges on the pump.
It has an arm which reaches into the engine (to the crankshaft, I assume), so there is oil in there (I believe). It then goes through the shot fuel pump and out it. That's the only thing I can come up with to explain it.
Keep us posted on the rebuild project, letting us know how it goes.
Fuel pump
Logan, you can still get a rebuilt fuel pump from USA Parts Supply, part # S3.900L . Requires a core to be sent or an extra charge will be added but you still can get one.... Tedd
Also, that is really, really awesome that it is still available, thank you for the info! I may still do the rebuild kit because it'd be a fun project, but as I'm going to need a vehicle soon (I'm borrowing a friend's car and I have to return it by the end of the month) I may just end up buying the entire assembly.
Also, thanks to everyone that is being very friendly and welcoming me to these forums, it seems like a great place!
I brought my 61 Dynamic 88 back from the dead after 20 or so years of sitting. The more I drive it, the more crap is breaking. I need to address my fuel pump. I can buy a rebuilt dual for $130 on ebay or a rebuild kit for $69 plus shipping. My question is...Is there an advantage or disadvantage to putting just a plain ole' mechanical fuel pump on and putting in a vacuum reducing valve from the manifold?
And by the way, this vacuum reducing valve...Is it an actual valve? or a fitting to reduce the size to the 1/8 vacuum line?
FYI-I'm not restoring this to original. I'm just getting it reliable for a daily driver.
Gary
Gary
johns59super88
October 29th, 2013 08:22 AM
