94 Olds Cutlass Supreme Convertible
Old Aug 15, 2018 | 07:04 AM
oldstoto6768's Avatar
I am normally a Toro Guy but I just purchased a '94 Olds Cutlass Convertible.... And I need the rear window moulding (see below) ...
i'm told that it is a unicorn but if anyone knows where it could be obtained, that would be great...!!. I've also been told I could use a
Camaro part but I want to be certain which part that would be and secondly exactly how do you use that part to put onto this car ?
Thanks, for anyone's help ....
Old Aug 15, 2018 | 09:08 AM
JohnnyBs68S's Avatar
Welcome! I always liked those early '90s Cutlass 'verts. Olds was the only GM division to drop the top on that body, making it a stand-out in my mind.
That exterior window felt looks just like the one used on the doors of the 4th-gen F-bodies (Camaro / Firebird). You'd probably have to trim it to the correct length (F-body doors are quite long), and improvise on mounting it.
(Sidenote: Digging the Olds Hotline: 1-800-442-OLDS)
Old Aug 15, 2018 | 10:21 AM
Thanks for the info .....the improvising of mounting it will be the issue ...
thanks again ...
i really like your 68 Cutlass ..,,!!
pteinert
Jul 20, 2013 09:09 AM
ros6872
Jun 14, 2013 04:00 PM
macpat321
May 21, 2008 12:31 PM
81cutlassconvertable
Mar 5, 2007 06:19 AM
