69 Cutlass Supreme - best way to pull from garage?
Old July 11th, 2018, 06:21 PM
ProfVanNostrand's Avatar
I need to pull this car out of a garage and into a yard to load onto a trailer.
What is the best way to hook up to the rear of the car so that I can pull it out?
I'd appreciate any help or advice you all can provide.
ProfVanNostrand is offline
Old July 11th, 2018, 06:49 PM
Cable or chain around the rear axle. Watch out for the brake line.
oldcutlass is offline
Old July 11th, 2018, 08:45 PM
OLDSter Ralph's Avatar
If you have front disc brakes, hope the pads aren't "glued" to the rotors. If they are...several short lengths of pipe under a plank on each side will make your job easier if its on concrete.
OLDSter Ralph is offline
Old July 11th, 2018, 08:53 PM
I haven't looked at it myself yet. A couple of people tried pushing it backwards but could only get it to rock back and forth a little.
Old July 11th, 2018, 08:54 PM
I was hoping to avoid that but I guess I might not be able to.
Old July 11th, 2018, 09:49 PM
Ah, so you are buying it. The rear brake pads could be "glued" also. I would recommend a rolling floor jack, eight or ten 1 foot lengths of pipe and two 6 foot planks (2" X 6") if shoes and pads are "glued" to drums and rotors. Jack one end at a time to see if either set of wheels (front/rear) turn.
If one set of wheels roll, use the rolling floor jack under the end that doesn't roll. A "come along" could be helpful. I would get the trailer as close to the car as you can. BE SAFE !
I have been down this road before, Good luck.
Old July 11th, 2018, 09:53 PM
One last thing...
As silly as this may sound.....make sure the tranny is in NEUTRAL.
Old July 14th, 2018, 09:51 AM
Be sure to use the stick brakes as a bargaining chip for a better price. 😎
matt69olds is offline
Old July 14th, 2018, 01:24 PM
marty59's Avatar
Provided the car is on concrete, some car/wheel dollies could come in handy too with some guidance.
marty59 is offline
Rocketman!442
Brakes/Hydraulic Systems
April 19th, 2016 12:40 PM
OLD SKL 69
September 1st, 2013 08:12 AM
olds69supreme
August 21st, 2008 10:41 AM
CUTLASS FREAK
September 17th, 2007 08:57 AM
CUTLASS FREAK
Drivetrain/Differentials
May 14th, 2007 08:05 AM
Quick Reply: 69 Cutlass Supreme - best way to pull from garage?
