1970 442 Build Questions!
Old Jun 15, 2018 | 12:14 PM
ToddCagle's Avatar
Hello my name is Todd and I have recently taken over a 1970 442 build from a guy who had taken the car apart. The guy originally building the car passed away from a motorcycle accident and now I have taken over completely. Its a full frame off restoration 442 convertible, 4 speed MT, AC, 455. I'm at the point of putting the car back together and I'm in need of some help. I have the 1970 fisher body service manual and the chassis service manual but some stuff is still unclear to me. For starters I have a plug under the dash that includes two thick solid purple wires near the brake pedal that goes into a plug that someone had cut and it also has two thick purple wires running to nothing except each other from the guy twisting the ends together. id also like to know what color wires goes into the clutch neutral safety switch. Also I'm in the process of assembling the front end and I have no idea where the grille mounts too when talking about the vertical mounting holes on each end of the grilles. Im sure I have a lot more questions but ill start with these two first. Thanks in advance! - Todd
Old Jun 15, 2018 | 12:23 PM
Welcome. Thick purple wires are the starter circuit and go to the Neutral Safety Switch. On a factory MT car, these would have been plugged into the clutch safety switch. The fact that they have been cut off suggests that this was not originally an MT car.
Old Jun 15, 2018 | 12:24 PM
My442's Avatar
Those wires go to the clutch safety switch that mounts on the pedal assembly.
It prevents the car from being started without the clutch pedal being depressed.
Old Jun 15, 2018 | 12:36 PM
ToddCagle's Avatar
okay awesome! thanks for the quick response. The wires are cut on the plug side not the harness side any ideas of where to get the plug? actually i just found it on fusick! will order it asap. any ideas on the grille? i feel like i might be missing a lower grille support.
Old Jun 15, 2018 | 03:58 PM
OLDSter Ralph's Avatar
Todd, Welcome and good luck. If you think about it sometime, edit your profile to let us know what country you live in, or even what state.
BSiegPaint
Jan 12, 2018 03:57 PM
rcdynamic88
Dec 19, 2017 06:27 AM
Eaglesfan
Dec 6, 2014 07:55 AM
bryndalfly
May 24, 2014 10:21 AM
Dave Siltman
Tech Editor's Desk
May 6, 2010 06:48 AM
