Where is the engine number located
If your talking about the casting numbers. Then you need to look at the shelf its the flat area behind the water pump in front of the intake. To the right of the oil filler tube.
Also welcome to the site.
Right behind the waterpump in front of the intake, this area may be filled with gunk and crud, wipe it out and post the numbers here. If it is a 400 from '68-69 there will be a vin derivative on a small pad below the number 1 cylinder.
jensenracing77
June 16th, 2011 03:14 PM
