vintage air help
Tim
Welcome to the site, post some pictures of your car when you get time. You may pose this question to Vintage Air and see if they have an accessory relocation kit available. If not you may have to mix and match as Tim said.
will looks like i am going to get the vintage air bracket for the pass side and find a bracket to move the alternator to the drivers side next to power steering pump as it is on a factory air car do you know anyone that has the alternator bracket
that would be great and how mch do you want for parts e-mail pwin489680@aol.com
Sounds best, especially if Nick has the parts you need. Plus you can route all the hoses and lines behind the inner fender instead of across the engine for a cleaner install. VA's solution for non-AC cars with the bracket on the drivers side is not the prettiest, at least on the '68-'72's.
ah64pilot
April 7th, 2012 04:53 AM
