Travelling North America in a 72 Cutlass
Back in Michigan
I'm now back at my uncle's in southwest Michigan, with the car running better than it was for most of the trip across the West.
Devils Tower, Wyoming:
Mount Rushmore, South Dakota (honestly, it's there. Tough to find a good spot to get the car and the monument in the picture):
The unfinished Crazy Horse monument, South Dakota:
Minuteman missile site, South Dakota:
Badlands National Park, South Dakota:
North Dakota State Capitol, Bismarck, ND:
From North Dakota I went into Minnesota, where I met up with Brian (1971four4two on the forum), who kindly helped me with a number of the issues I was having. We fitted his spare 3-row (golden) radiator which immediately solved my cooling issues, and had a look at the brakes. On the driver's side, the drum was very tough to remove. This was the view:
On the left, the hold-down pin, and washer were missing, ground into dust inside the drum. The remains of the spring were floating around inside:
$8 spent at the parts store:
(spot the new part)
My car alongside Brian's:
Huge thanks to Brian for his help and hospitality.
I then carried on to Wisconsin, where I met up with Dave, who along with his wife kindly fed and sheltered me for the night, as well as showing me his beautiful 62 Dynamic 88, as well as his pair of Cadillacs, one from 1955, one from 1992. Thanks to Dave and Jean for their kindness and hospitality.
Heading north I stopped at Road America for a nose around:
In Green Bay I had a look at Lambeau Field ...
... before arriving at my stop for the night, camping in the National Forest in the Upper Peninsula of Michigan:
I was no longer an obvious tourist, with the car back in its home state. Seeing as it was built in Lansing, it's nice to keep the Michigan connection.
Whitefish Point Lighthouse, 16 miless off which the Edmund Fitzgerald sank:
Another of the Lake Superior lighthouses:
The International Bridge at Sault Ste Marie:
I then turned south on the home leg back to my uncle's. I stopped for a view of the famous Mackinac Bridge;
So I'm back, had a couple of days relaxing and now back to focusing on the car. I've done about 36,000 miles now since owning it. I am planning to attend the Red Barns show at the Gilmore on Saturday, also I am thinking of making a trip out to Detroit some time while I'm here where I'd love to meet up with some of the Olds owners in the area. Closer to home, anyone in the Kalamazoo / Battle Creek area?
I'm a little confused by my battery mounting problem which I'd like to fix. I currently have a plastic battery tray, which has cracked on the bottom and a piece on the side has snapped off. I have a hold down clamp, but have no idea where it would go. How is my battery supposed to be secured in a 72? Anyone got a picture or diagram? I've had a look on the net and battery trays are easy to find, any thought on which is highest quality?
I'm thinking I can now remove the hose the Vegas mechanic added, from the transmission vent tube to the dipstick. I see the service manual calls for a change of transmission fluid and filter, is this still advisable with modern transmission fluid? Any suggestions on service jobs I should do? I changed oil and filter at Brian's, I have just bought a new air filter and fuel filter, and will check diff oil level (thanks Brian for suggesting this). Last time I bought a emission canister filter only to discover it is not hooked up.
To answer some questions/comments:
Rob - thanks for your detailed reply, I will definitely have a look at those valves. The AC is not quite right for sure. Here in Michigan it's not as hot as it was in SD, but still the humidity is high enough I would like it working.
Naming the car - honestly I've never given a car a name. Just isn't something I do. I have definitely developed an emotional attachment to the car though.
1969oldsH - I don't stay in one place too long in general, that's true - mainly because I wouldn't be able to get to everywhere in time. If I stay somewhere longer, it's always because I have friends or family that can put me up easily. Sometimes I would like to stay longer somewhere, but I have to be ruthless and keep driving.
btrbill - I'll have left the country and the car will be on a ship by the time those shows come around. I'll let you know when I'm your area though.
zippy - not though about that, I'm travelling alone so I'm always behind the camera. I'll try to get a picture of me and the car on here.
(spot the new part)
Last edited by Zindon; Jul 31, 2012 at 02:49 PM. Reason: answering some specific questions
Oliver the dim alt light is caused from a failed diode in the alternator there are three of them one for each winding in one package commonly called a diode trio or diode pack. I bet the light pulsates by the engine rpm that is because one diode is shorted out allowing the lower portion of the alternating current (AC) to pass to the battery. As the engine rpm goes up the AC frequency goes up causing the light to flicker faster. You can replace the diode trio just take the alternator off the car then there are a few screws holding the alternator together take them off and open the case you will see it straight away. Remove the diode trio and apply some dielectric grease to the three contact points of the new one and install it the same way you removed the old one. Put the case back together and install it back in the car. If you are planning on a trip to Milwaukee WI send me a e-mail or pm I always have room for another Oldsmobile plenty of tools, cold beer not that warm stuff
If it's important to you to have the right one, then I'm sure a member here could find one to sell you.
The original battery tray should have a ridge all around the edge, with two "tabs" that rise higher than the ridge and have slots in them. The two hold-down rods (threaded rods with hooked ends) should engage these slots, and the cross-piece then slides over the threaded portions of the rods and is secured to them, holding the battery down. It is possible that one half of this cross-piece accepts a threaded rod and the other half screws to the core support as well (I've seen so many different arrangements over the years that I really can't remember perfectly).
Since you don't have an original tray, and since the plastic tray you do have is broken, though, a couple of carefully arranged bungie cords should do fine, and may be stronger than the original system was.
There are some differences (improvements?) between newer and older fluids, but I've not heard of them affecting change intervals.
You may as well change the fluid, filter, and gasket, and I agree that you don't need the hose if the engine's now running cool.
As for other things to check: Get 'er up in the air and give 'er a good once-over.
Recheck your brakes, check ball joints and tie rods, check suspension bushings, check U-joints, check wheel bearings, check hoses for leaks, check exhaust hangers and clamps, put a bit of grease on things that move (hinges and latches, transmission linkage, etc.).
We're all envious of your trip!
God, what a wonderful journey you've had!!
Next time, stop and pick me up, lol. I'd love to do something like that. I've been to a lot of the places in your pic's - I love the West. It's just sooooo beautiful out there. I've been to the UP also, as I have an ex brother in law who lives in Eastpointe now, but grew up around Grayling. He took us up to Sault Ste Marie once - I thought the locks were pretty neat. I loved the Edmund Fitzgerald museum there. I brought home some pretty rocks from Lake Superior and put them in my fish tank, lol. Beautiful country up there.
Glad you made it back safely. Thank you so much for sharing your trip with us!
Hey Olly
Glad your Olds car took you to michigan without any more trouble. By your pictures it looks like you took the scenic route again. Thanks for sharing the cool photos from along the way.
Brother where you bound??
Cheers
Brian MN
Cheers
Brian MN
The trip is not over, I am leaving Michigan in the next couple of days to head south. Kentucky, Tennessee, Missouri, Mississippi and Alabama to go, then Houston to ship the car home. Thanks again to Dave and Jean for their hospitality - and the picture.
Oliver, thanks for sharing your wild adventure. I admire your choice in vehicles, your itinerary, sights chosen, drive..... Also I love the way you take pictures with your Cutlass positioned as the main object of interest. I"m glad you're enjoying the USA.
Sorry for the lack of updates, I am still alive. My laptop has broken which is very frustrating as I have to use my phone for everything. I am now in Houston so am pretty much done. Only issue is the brakes are making unpleasant noises again
Shipping is arranged so in a couple of months I should be Oldsmobiling around Great Britain.
I do hope this means the adventure continues when you gat back to the UK with your car... Some pics by big ben? stonehenge? the lakes distrct?
Just saying, the adventure needs to continue! we need inspiration while working on our cars!
Zindon, too bad your adventure is coming to a close...
There are a few great members there in Houston who might be able to get your brakes fixed, or at least be able to help you get all the parts you need to ship back with the car so you can fix it back in the UK.
You did what I have always wanted to do and I envy that. I am glad you had a fun time and you will certainly cherish the memories.
Hope you and your car have a safe trip back home. Keep us updated on future events!!
Great story indeed. Wish I had known when you were traveling through North Carolina. You probably passed right through my city on your way from to the Outer Banks from West Virginia.
For what it's worth, a lot of chain auto parts stores like AutoZone will loan out tools for free and let you work on your car in their parking lot. I've also had them offer to lend a hand for a few minutes if things are slow inside the store. One time when I bought a battery at AutoZone, the guy left a wrench (spanner) behind when he installed the battery.
Was Quality time when OLLY had breakdown half close to my garage
I modified his cooling RAD
and he went into the ghetto with my DADDIO to get front drum brake parts
METAL on METAL since the mountains
I hope to see his oldsmobile in my driveway again
Give a HOOT dont Pollute thread
Great story Oliver! I'll repeat what others have said that you have travelled more of the country than many that live here. Many Brits don't really grasp the size of USA and Canada. I have relatives in Somerset and they contacted us once to say they were landing in Gander NL, would stay the day then drive over to Toronto ON in the afternoon - lol!
Lady72nRob71
Apr 28, 2013 09:20 PM
