SBO build
Old Nov 26, 2013 | 04:23 PM
lostboys65's Avatar
SBO build
Boys and Girls,
Need some advice on a SBO build. I want to put some meat into my SB 72 Cutlass convertible. I was going to do a BB but block had been bored 60 over and machinist said walls were scored and block was maxed out as far as bore so I decided to go with a SB. Since the car is a 29K mile original I am saving the drive train in case next owner is a purist. I have a 69 block with #2 nickel content. I have Edelbrock Aluminum heads that I had machined (70 cc chambers) and going with Edelbrock Performer RPM intake. When asking Edelbrock for advice on a 750 cfm carb they said can't do b/c of egr valve. As far as I know they did not start putting egr valves on GM cars until 1973. Am I wrong? Anyway, any problems with Edelbrock Intake manifold #2711 with an Edelbrock 750 cfm carb # 1411.
I am putting flat top pistons (JE) and Carrillo connecting rods in this machine with a T5 behind it. Have a build 10 bolt 8.5 GM ring diff with Yukon posi and 3.73 gears (could not find any ring and pinions gears for the 12 bolt O carrier I was going to use). Heads have roller rockers from Mondello.
Any other suggestions to make this special?
lilgiff
Oct 20, 2012 10:15 PM
MR73OLDS
Apr 13, 2012 05:17 AM
yankees
Nov 28, 2011 10:07 AM
f-85
Aug 15, 2010 11:15 AM
shaks 442 clone
Oct 18, 2008 09:41 AM
