Russ
Russ
Hello, I'm new to Classic Oldsmobile. Signed up a few days ago. I own a 1965 Starfire Convertible. This was my first new car. I bought it new in February '65, drove it 10 years and put it away in my Dad's garage. It sat there for about 30 years. Goy it back on the road about 5 years ago. Last year I decided restore it. Have done nothing with the engine. I'm debating whether to rebuild it or just leave it and put new seals in it. I'd appreciate any and all opinons on this.
Glad I found the web site. I'm sure it'll be very beneficial as I go through the restoration.
Russ
Russ
Welcome Russ.
That's an age old debate you've got there. My opinion FWIW is that if you're going to put in new seals? You have the engine apart to do that, so you may as well go all the way. How many miles on it? If it's been sitting for 30 years and you just started driving it again 5years ago, I'd almost bet you're seeing oil drips under the car.
I'm in a similar situation with mine , so I decided a rebuild is in order next spring. I have 120K on mine. Compression is down, it leaks but starts and runs nicely! Have to look past the surface to what the engine really needs. Suggest you do a compression test on it to see how it weathered the years.
