Running dual quads on a 394
Old Aug 21, 2015 | 11:44 AM
Ezln1688's Avatar
Hi new to the forum and Oldsmobile world! I have a 64 98 that I picked up a few months back, the odometer reads 55k car runs great other than leaking a lil oil. I did a dry compression test and got 150 on all. I em thinking of running dual quads in the future and wondering if the motor will be able to take it or would I have to do other mods prior to that?? I will also be swapping to the 200 r4 as the slim Jim on this is ****.
Old Aug 21, 2015 | 12:00 PM
Welcome to the site. I'll let others chime in on the dual quads and the trans swap. Post some pics of your 64 when you get a chance.
Old Aug 21, 2015 | 01:28 PM
therobski's Avatar
If the carbs are tuned correctly, should not have a problem. If the 394 is original to the car its a high compression engine anyway. If were me, I would locate a J-2 setup, much sexier! Either way you will not see much of a "seat of the pants" power gain. I would invest in the 200-4R conversion first, just a suggesion. X2 send us some pictures please.
Old Aug 21, 2015 | 01:41 PM
Ezln1688's Avatar
Yeah those j-2 set up are sexy as hell but I have 2 elderbrock 500 spread bore laying arround that I could save some money with! I will upload pics as soon as I figure out how to guys
Old Aug 21, 2015 | 03:42 PM
Oldsmaniac's Avatar
I dont think the J-2 manifold is compatible with the later 394 blocks. There was a change in 59 and thats why no 3 2's on the 59. 58 was the last for that series engine. There are aftermarket intakes for multi carbs on these engines. A simple carb or multi carb swap will not hurt a good engine, its only the beating that may take place after some new ponies are acquired !
Old Aug 21, 2015 | 05:22 PM
therobski's Avatar
Oldsmanic, you are correct brother, just when you think you know it all! The J-2 Tri-Power setup will not fit the 394. There were differences between the 371 and 394, I believe in the port sizes. The 394 intake passages are much larger. Thanks.
Old Aug 21, 2015 | 05:55 PM
Actually, you really just need spacer plates due to the slightly taller deck.
As for the dual quads, I ran a pair of 500 CFM Carters (precursor to the Edelbrock) on a 455 with a progressive linkage. The car was very streetable and actually got 15-ish MPG in a 71 Cutlass with 3.42 gears and my heavy foot.
Old Sep 2, 2015 | 09:22 PM
Ezln1688's Avatar
Here are a couple random pics of the olds that I have on my phone, I will upload more *** soon as I get it rolling kind of just have a bunch of parts laying around ready to be thrown in there at this point
Old Sep 13, 2015 | 08:54 PM
64Rocket's Avatar
You will have to have a adapter made to install the 200r4 trans.
Ross Racing makes the adapter for a T-400, may have to talk to him.
Gene
Old Sep 13, 2015 | 09:07 PM
Ezln1688's Avatar
Will I really? I thought that was only for the 700r4?
garyr6169
Dec 21, 2014 01:59 PM
Carl, uk
Mar 13, 2014 05:43 AM
Vader
Feb 26, 2013 02:25 PM
Nasty455
Mar 15, 2012 05:56 PM
Techcompsolutions
Feb 6, 2011 01:29 PM
