Rocker shaft removal 64 394
Old Jun 13, 2018 | 11:47 AM
64OldsDynamic88's Avatar
This may have been an earlier thread but I can't seem to locate one.
It looks like some of the bolts for the rocker shaft are also head bolts. If I remove the rocker shafts what is the risk of having to replace the head gasket? Or, is there enough other bolts that there shouldn't be an issue.
Oh yeah I'm talking about a 1964 Olds 394
Old Jun 13, 2018 | 11:54 AM
redoldsman's Avatar
Proud Viet Nam Veteran
That should not be a problem. I have done it on my 324 with no problems. Just be sure are retorque the bolts.
Old Jun 16, 2018 | 12:29 AM
Ozzie's Avatar
As indicated, it should not affect the head gasket. The removal/install procedure for the rocker arm shaft assembly is covered on page 3-4 of volume 1 of the 1964 Oldsmobile Service Manual. Upon installing, tighten the bolts incrementally. Torque the large bolts to 60-80 ft.-pounds. Tighten the small bolts to 14-22 ft.-pounds.
Chuck Cole
Oct 19, 2018 02:51 PM
Haidda
Apr 11, 2018 01:26 AM
51olds88
Jun 2, 2013 08:35 AM
Olds Scott
May 29, 2013 08:15 PM
70cutty
Aug 15, 2008 03:14 PM
